Corporate News Index
June 6, 2008
New Conformal Coating from DYMAX Meets MIL-I-46058C and IPC-CC-830B Requirements
DYMAX Corporation, the leader in light-curing technology for electronic materials, announces that Conformal Coating Multi-Cure® 987 has met the requirements of MIL-I-46058C and IPC-CC-830B. Multi-Cure 987 is specifically formulated for rapid room temperature cure when exposed to UV and/or visible light. Any coating in shadowed areas on densely populated circuit boards may be cured with heat. Based on DYMAX Multi-Cure® 984-LVUF, 987 is designed with better wetting on circuitry and components. This product dispenses easily and cures quickly for precise quantity and placement.
Multi-Cure 987 is blue fluorescing under “black” light for easy inspection, and is chemically resistant for better protection. The viscosity is optimal for spraying thin coatings of 0.001" – 0.003" thickness.
DYMAX coatings contain no non-reactive solvents and cure only upon exposure to UV and/or visible light and/or heat. Their ability to cure in seconds enables faster processing, greater output, and lower assembly costs.
DYMAX Corporation is a technology-based company specializing in the formulation, manufacture and service of advanced assembly adhesives, coatings, epoxies, masking resins, and light curing systems.
DYMAX Corporation
Jackie Somsichack
http://www.dymax.com/
This page has been viewed 331 times.
More from DYMAX Corporation
DYMAX Corporation
November 13, 2008 - Corporate News
New Dymax ACCU-CAL™ 50V Visible Radiometer
Dymax Corporation
DYMAX - One of the Fastest-Growing Companies in the U.S.
DYMAX Corporation
October 23, 2008 - Corporate News
DYMAX + PARTNER PAK = Sustainable Clamshell Packaging Technology
DYMAX
October 22, 2008 - Corporate News
DYMAX Plastic-Bonding Adhesives Pair Well with New BlueWave® LED Spot Curing System
DYMAX Corporation
DYMAX Acquires Dispensing Leader Tridak
DYMAX Corporation
September 26, 2008 - Corporate News
DYMAX Corporation
September 25, 2008 - Corporate News
DYMAX
September 24, 2008 - Corporate News
New DYMAX ACCU-CAL™ 50V Visible Radiometer
DYMAX
DYMAX
New Moisture-Resistant Gasketing Resin from DYMAX
DYMAX Corporation
July 28, 2008 - Corporate News
DYMAX BlueWave LED System Now CE Marked for Global Distribution
DYMAX
DYMAX Corporation
July 14, 2008 - Corporate News
DYMAX Introduces Fluorescing Light-Curing Needle Bonding Adhesive
DYMAX Corporation
July 11, 2008 - Corporate News
Fluorescing Light-Curing Needle Bonding Adhesive from Dymax
DYMAX Corporation
June 6, 2008 - Corporate News
DYMAX Corporation
May 8, 2008 - Corporate News
New Conformal Coating from DYMAX Meets Requirements
DYMAX Corporation
May 7, 2008 - Corporate News
Mr. Kyle Rhodes Joins DYMAX as Medical Market Segment Manager
Dymax
May 6, 2008 - Corporate News
Mr. Terrence Woldorf Joins DYMAX Corporation's Sales and Marketing Team
DYMAX Corporation
April 16, 2008 - Corporate News
Get Cool, Consistent, Visible Light Curing with New DYMAX BlueWaveTM LED System
DYMAX Corp.
180° Curing w/ New DYMAX UVCS SideCure™ Conveyor System
DYMAX Corp.
April 14, 2008 - Corporate News
Rob Kleinschmidt Joins DYMAX as Sales Engineer
DYMAX Corporation
April 10, 2008 - Corporate News
DYMAX Introduces See-CureTM Technology
Dymax
DYMAX Corporation
March 26, 2008 - Corporate News
DYMAX Corporation
To find more articles from DYMAX Corporation, use the search form below.
