| Letter to the Editor |
Index |
Jun 3, 2008
Leaded Solder on ROHS Compliant Parts?
Recently there was a question about Leaded Solder on ROHS Compliant Parts. One of the experts said "No, using leaded solders on a lead free application will work just fine. You might notice a small difference in the wetting characteristics of the assembly but just remember to keep the temperatures low and if possible use a variable power soldering iron."
It's kind of a side note but, one thing they did not mention is BGA parts in a leaded process. In theory, ROHS parts shouldn't have any problems with leaded solder. But in the case of ROHS BGA's, the ROHS balls do not collapse during a leaded solder reflow profile. We just had this problem and we found that we have to find leaded versions of these parts so they will reflow properly.
Donavin Bensmiller
Northern Airborne Technology
This page has been viewed 261 times.
Comments
Do you have a comment to offer? Use the form below.
