May 29, 2008
PullTester 20 Low Cost Pull Test Device
Schleuniger’s PullTester 20 is a motorized, bench-top unit designed to measure pulltest forces for a variety of applications. The most common are wire crimp and ultrasonic metal welding connections, but the design makes it possible to create custom fixtures for many others.
Standards such as IEC and SAE specify that the device pulls at a consistent rate. The Schleuniger PullTester 20 is equipped with a speed-controlled motor, ensuring consistent pull rates throughout the measuring range which means repeatable and accurate data. Pullto-break (destructive) tests can be measured in pounds, Newtons or kiloponds.
The standard 12-position terminal holder accommodates a wide variety of terminals to suit most applications. A variety of terminal holders are available upon request. The machine will test pull forces up to 110 pounds (500 Newtons) and is specially suited for quality assurance in a production environment.
Other features include a simple LCD-display for easy digital pull force read out, two selectable pulling rates and a RS 232 interface for curve analysis and export to Microsoft EXCEL software.
Schleuniger
http://www.schleuniger-na.com
This page has been viewed 196 times. |
More from Schleuniger
YESTech
IPC
PROMATION, Inc.
A.C.E. Opens Selective Soldering Process Development Lab
Cobar
XDry Corporation
Krayden
Pennies Well Spent
PULS UK
ZESTRON America
DYMAX Corporation
Fine Line Stencil
Reed Exhibitions
AVX Corporation
Littelfuse
CheckSum
Orbotech Ltd.
Essemtec
In a move that will help PCB designers work with greater accuracy and efficiency, IPC — Association Connecting Electronics Industries® has ...
IPC
CheckSum
Federal Electronics
Crystek Corporation
SchmartBoard
KIC
IPC
To find more articles from Schleuniger, use the search form below.
