Corporate News Index
May 29, 2008
New DYMAX BlueWaveTM LED System
Get Cool, Consistent, Visible Light Curing
The new BlueWave™ LED visible light, high-intensity spot curing system from DYMAX Corporation offers many advantages over traditional UV spot curing systems including… no bulbs to change, cool cures, no warm-up, and constant intensity for thousands of hours. The BlueWave LED generates light using an array of surface mount LEDs (Light Emitting Diodes) instead of traditional metal halide or mercury bulbs. The LEDs produce visible light energy in a relatively narrow wavelength band centered at 410 nm, as contrasted to a typical broad band, high-pressure UV bulb (300-500 nm). This system emits a maximum visible light intensity output of over 2,500 mW/cm2 from an 8 mm diameter lightguide, and allows users to adjust intensity output from 0% to 100%. The relatively narrow band produced by LEDs generates cooler curing temperatures. The BlueWave LED is excellent for spot curing of coatings, as well as adhesive bonding of polycarbonate, PVC, PET, metal, glass and many other substrates.
The BlueWave LED curing system can cure many of DYMAX’s visible light curing adhesives that are currently being produced. Their Applications Engineering Group can offer adhesive recommendations for assembly processes utilizing the BlueWave LED curing systems.
DYMAX Corporation is a technology-based company specializing in the formulation, manufacture and service of advanced assembly adhesives, coatings, epoxies, masking resins, and UV curing systems.
DYMAX Corporation
http://www.dymax.com
This page has been viewed 161 times.
More from DYMAX Corporation
Credit Turmoil Cuts 2009 PC Outlook by Nearly Two Thirds
iSuppli Corporation
YESTech
IPC
PROMATION, Inc.
A.C.E. Opens Selective Soldering Process Development Lab
Cobar
XDry Corporation
Krayden
Pennies Well Spent
PULS UK
ZESTRON America
DYMAX Corporation
Fine Line Stencil
Reed Exhibitions
AVX Corporation
Littelfuse
CheckSum
Orbotech Ltd.
Essemtec
IPC
CheckSum
Federal Electronics
Crystek Corporation
SchmartBoard
KIC
To find more articles from DYMAX Corporation, use the search form below.
