Corporate News Index
May 19, 2008
Essemtec Announces Ability to Dispense Material and Place LEDs on Film Substrates
Essemtec AG, a leading manufacturer of surface mount technology production equipment, announces that it can perform material dispensing and consecutive placement of LEDs on film substrates.
Ever more electronics manufacturers are required to economically dispense solder paste, isolating adhesives and placing LEDs on film substrates. Essemtec AG has developed a solution that can fulfill this growing need both efficiently and precisely.
Based on Essemtec`s proven placement machine FLX2010 MKL, a concept with a three-head system was designed. The head features a placement axis with an integrated component adjustment mechanism, as well as two independent axes with a piezo flow valve and a time-pressure dispenser gear. The dispensing valves are mounted on motorized, closed-loop driven precision linear axes to ensure an accurate movement in the Z-axis. The substrate is positioned on the machine table and is secured by vacuum. The spacious machine concept allows the handling of substrates in the format of 800 x 600 mm. The substrate is manually placed on the vacuum table and then adjusted to the positioning pins.
The vacuum is activated with a foot-operated switch, and the film substrate firmly sticks to the table. After the fiducials have been recognized by the vision system, the time-pressure dispenser applies three dots of isolating adhesive on the substrate — a larger one in the middle and two smaller dots aside. Then, solder paste dots are applied on the substrate solder pads using a high-precision, piezo-controlled PFV nozzle. The LEDs are then picked from Essemtec standard feeders, adjusted and accurately placed. The isolating adhesive, applied prior to the placement operation, eliminates any unwanted electrical contact between the solder dots.
The entire procedure at a glance consists of five steps:
  1. Apply film substrate, adjust and activate vacuum by foot switch
  2. Recognition of fiducials
  3. Dispensing of dielectric adhesive, three dots per each LED
  4. Placement of LEDs
  5. Deactivate vacuum, take substrate from the table.
The system was designed using only Essemtec’s standard placement modules. These modules feature high reliability and durability, and more than 600 are installed worldwide. Custom-specific adaptations and applications are planned and realized quickly and in cooperation with the users.
Essemtec
Adrian Schärli
http://www.essemtec.com
This page has been viewed 218 times.
More from Essemtec
Essemtec
November 12, 2008 - Corporate News
Automatic SMD Insertion of Silicone Keys
Essemtec
October 9, 2008 - Corporate News
Essemtec to Exhibit at Mexitrónica
Essemtec
October 1, 2008 - Corporate News
Essemtec Opens New Demo and Training Center in Suzhou, China
Essemtec
September 23, 2008 - Corporate News
ESSEMTEC to Exhibit SP003-MLV at IPC Midwest
Essemtec
ESSEMTEC to Display RO300FC-C at IPC Midwest
ESSEMTEC
ESSEMTEC to Introduce SP150 at IPC Midwest
ESSEMTEC
ESSEMTEC to Feature EXPERT-SAFP Prototyping Station at IPC Midwest
Essemtec
ESSEMTEC to Display New Placement Machine at IPC Midwest
ESSEMTEC
ESSEMTEC to Premier FLX2011 to North American Industry at IPC Midwest
ESSEMTEC
Essemtec Introduces FLX2010C System
Essemtec
Essemtec Introduces Semi-automated Paste Printer Features
Essemtec
Essemtec Premiers Automated Printer with Sideways Moving Loading Drawer
Essemtec
ESSEMTEC Wins Global Technology Award for Multi-Flexible Production Solution
Essemtec
Essemtec provides even more customer benefits with enlarged service portfolio
Essemtec
August 20, 2008 - Corporate News
Essemtec's Placement Machine for Flex Board and Film Substrate Features Twin Vacuum Table
Essemtec
Essemtec to Highlight SP003-MLV Semiautomatic Stencil Printer with Vision at NEPCON South China
Essemtec
August 15, 2008 - Corporate News
Essemtec Introduces Semiautomatic Printer
Essemtec
ESSEMTEC to Highlight SP003-MLV at SMTAI
ESSEMTEC
New placement machine for small to middle-sized production volumes from ESSEMTEC at NEPCON South China
Essemtec
August 13, 2008 - Corporate News
ESSEMTEC to Exhibit RO300FC-C at SMTAI
ESSEMTEC
ESSEMTEC to Feature EXPERT-SAFP Prototyping Station at SMTAI
Essemtec
Essemtec Introduces Semiautomatic SMT Prototyping System at NEPCON South China
Essemtec
August 7, 2008 - Corporate News
Essemtec Introduces Updated Web Site
Essemtec
August 6, 2008 - Corporate News
ESSEMTEC to Display New Placement Machine for Small and Mid-Size Production at SMTAI
Essemtec
To find more articles from Essemtec, use the search form below.
