RANCHO CUCAMONGA, CA — Aqueous Technologies Corp. announces that it will introduce the Trident, its fourth-generation automatic defluxing system, in distributor SYSTRONIC stand 7-431 at the upcoming SMT/Hybrid/Packaging 2008 exhibition and conference - scheduled to take place June 3-5, 2008 in Nürnberg, Germany.
