May 16, 2008
Littelfuse 250 VAC Surface-Mount Time-Delay Fuse Series
Improves Circuit Protection of Printed Circuit Boards
New fuse series provides high inrush current withstand (I2t) capability for 250VAC, while maintaining a very small footprint for crowded circuit boards
DES PLAINES, IL - Littelfuse, Inc. (NASDAQ/NGS:LFUS) today introduced its 0443 surface mount time-lag fuse line for overcurrent protection of printed circuit boards.
With dimensions of approximately 10.1 x 3.12 x 3.12 mm, these fuses are ideal for applications with the higher 250 VAC requirement and where space is limited.
They have inrush current withstand (I2t) ratings of up to 127A2s (5A current rating) along with a time lag characteristic. This means lower probability the fuse will open during momentary overloads, which can add up to lower warranty board replacement costs.
The small size characteristic of the 0443 Series was designed to be particularly attractive to OEMs of products that have AC inputs for LED lighting, notebook PC power adapters, or any AC/DC power module.
The 0443 Series offers current ratings from 500mA to 5A, all with an interrupting rating of 50A at 250VAC.
This product series complements Littelfuse's broad line of DC surface mount fuses used on the secondary side of power circuits, with ratings from 62mA to 15A at voltages from 24 to 350VDC.
As a market leader in surface-mount fuse technology, Littelfuse offers OEMs production capacity for high volume demand, and fast production ramp-up for short lead times. Its DC surface mount fuses are used in demanding applications such as protection of lithium battery packs, DC/DC converters, LCDs, and telecom line cards. Agency approvals of these products include UL, CSA, METI and VDE.
Availability OEM samples of the 0443 Series are available from stock. Tape and reel orders typically ship 4-6 weeks ARO.
Click Here For Detailed Specification Information or visit Littlefuse website.
Littelfuse, Inc.
http://www.littelfuse.com
This page has been viewed 141 times. |
More from Littelfuse, Inc.
To find more articles from Littelfuse, Inc., use the search form below.
