Home  I  Site Map  I  News  I  Corporate News  I  Exclusives  I  Experts  I  Equipment  I  Directory  I  Calendar
  Corporate News Index
May 14, 2008
Fiber-Based Industrial Laser to Deliver High Power Picosecond Pulses
Santa Clara, Calif. – Coherent, Inc. (Santa Clara, CA) (Nasdaq: COHR) has launched the Talisker as the world’s first fiber-based laser to offer high power, picosecond output in a rugged industrial package. With over 18 watts of average power at a pulse repetition rate of 200 kHz (pulsewidth < 15 ps), this first fiber-based laser from Coherent will enable precision micromachining at high throughput rates with a negligible HAZ (heat affected zone). And, with a choice of infrared (1064 nm), visible (532 nm) or ultraviolet (355 nm) output, Talisker can be used on virtually any material type, including metals, polymers, glass and semiconductors. Talisker is also configured to facilitate integration and for ease of use. For instance, its internal web server simplifies remote diagnostics and preventative maintenance. Plus, the compact laser head measures only 17 cm x 39 cm x 77 cm.
Talisker is a mode-locked laser with a unique architecture that combines the desirable characteristics of both fiber-based and free space lasers, while avoiding the inherent limitations of each. Specifically, Talisker utilizes a fiber-based oscillator that ensures industrial-grade stability, together with a bulk amplifier that boosts peak powers to higher than 10 megawatts. In contrast, traditional fiber lasers are limited to peak powers that are orders of magnitude lower than this to avoid self-damage.
Talisker is intended for micromachining applications in the microelectronics, biomedical, semiconductor and solar device industries. Specific applications include drilling high quality holes in silicon and metals, direct write of flexible circuits/displays, scribing of flat panel displays/solar cells, micro milling, wafer dicing and metal surface treatments.
Coherent, Inc.
Chris Dorman
http://www.Coherent.com
This page has been viewed 81 times.
More from Coherent, Inc.
June 11, 2008 - Corporate News
Turnkey Diode Laser System Delivers Higher Power & Brightness
Coherent, Inc.
May 14, 2008 - Corporate News
Coherent, Inc.
April 7, 2008 - Corporate News
Unique UV Laser Enables High-Speed IC Die Singulation
Coherent, Inc.
December 5, 2007 - Corporate News
New Laser Delivers Power and Beam Quality
Coherent, Inc.
November 8, 2007 - Corporate News
Solid-State UV Laser for Drilling and Micromachining Applications
Coherent, Inc.
October 2, 2007 - Corporate News
Compact UV Laser for Economical PCB Fabrication and Wafer Inspection
The new Paladin™ Compact 355-4000 from Coherent, Inc. is the first solid-state, ultraviolet laser to deliver 4 Watts of quasi-CW output (at 355 ...
Coherent, Inc.
To find more articles from Coherent, Inc., use the search form below.
Free Subscription  |   Industry Forums  |   Equipment Mart  |   Exclusives  |   Letters  |   Directory  |   News  |   Site Map  |   Viewpoint  |   White Papers
