Home  I  Site Map  I  News  I  Corporate News  I  Exclusives  I  Experts  I  Equipment  I  Directory  I  Calendar
  Corporate News Index
May 14, 2008
WireTwist 500 Benchtop Twisting Machine
The WireTwist 500 is a programmable machine for twisting multiple single wires (e.g. twisted pair). Twisting single wires gives the twisted wires higher stability for easier wire routing and improved protection against electromagnetic interference. The machine consists of an electrical drive unit and a compact holding unit.
The WireTwist 500 twists pre-processed wires that have been stripped, crimped or sealed. The final wire length (twisted) depends on wire diameter and pitch length of the twists. Minimum wire length is approximately 18” (450 mm) and maximum wire length is approximately 79” (2,000 mm). Longer wires up to 197” (5,000 mm) are also possible using a wire guide between the power unit and holding unit.
Programming the WireTwist 500 is simple. A clearly structured display allows quick adjustment of revolution speed and number of revolutions (forward and reverse). Parameters can be saved to and loaded from the internal memory. This allows processing of different applications with high repeatability and consistent quality without compromising flexibility.
Change-overs to different wire lengths and wire diameters are also done quickly and easily. Custom adapters for wires with housing or other special applications can be made according to customer specifications.
Schleuniger
Cheryl Duszak
http://www.schleuniger-na.com
This page has been viewed 102 times.
More from Schleuniger
June 9, 2008 - Corporate News
Schleuniger Group acquires PAWO AG
Schleuniger Group
May 29, 2008 - Corporate News
PullTester 20 Low Cost Pull Test Device
Schleuniger
May 15, 2008 - Corporate News
New 4-Station Automatic Crimping Machine
Schleuniger
May 14, 2008 - Corporate News
Schleuniger
March 11, 2008 - Corporate News
Precise & Powerful: the PreFeeder 60
Schleuniger
January 24, 2008 - Corporate News
Schleuniger Launches New Spanish Website
Schleuniger
December 17, 2007 - Corporate News
Improved JacketStrip 8400
Schleuniger
To find more articles from Schleuniger, use the search form below.
Free Subscription  |   Industry Forums  |   Equipment Mart  |   Exclusives  |   Letters  |   Directory  |   News  |   Site Map  |   Viewpoint  |   White Papers
