May 14, 2008
New 787-805 MHz VCO From Crystek Corporation
Fort Myers, FL – Crystek's CVCO55CC-0787-0805 VCO operates from 787 MHz to 805 MHz with a control voltage range of 0.3V~4.7V. This VCO features a typical phase noise of -122 dBc/Hz @ 10KHz offset and has excellent linearity.
The model CVCO55CC-0787-0805 is packaged in the industry-standard 0.5-in. x 0.5-in. SMD package. Input voltage is 5.0 V, with a max current consumption of 35 mA. Pulling and Pushing are minimized to 0.05 MHz and 0.05 MHz/V, respectively. Second harmonic suppression is
-15 dBc typical.
The CVCO55CC-0787-0805 is ideal for use in applications such as digital radio equipment, fixed wireless access, satellite communications systems, and base stations.
Pricing for the CVCO55CC-0787-0805 will start at $18.46 ea. in volume. For additional pricing details, contact Crystek Corporation.
Crystek Corporation
http://www.crystek.com
This page has been viewed 104 times. |
More from Crystek Corporation
October 6, 2008 - Corporate News
New 3366-3597 MHz VCO From Crystek Corporation
Crystek Corporation
September 18, 2008 - Corporate News
New 5340-5390 MHz VCO From Crystek Corporation
Crystek Corporation
August 25, 2008 - Corporate News
New 200-239 MHz VCO from Crystek Corporation
Crystek Corporation
New 136-174 MHz VCO From Crystek Corporation
Crystek Corporation
August 4, 2008 - Corporate News
Crystek Launches New 5x7 SMD True Sinewave Saw-Based VCO
Crystek Corporation
August 1, 2008 - Corporate News
Crystek Corporation has released its Model CVS575S-500
Crystek Corporation
July 17, 2008 - Corporate News
New 950-2050 MHz VCO From Crystek Corporation
Crystek Corporation
June 19, 2008 - Corporate News
Crystek Introduces The REDBOX Amplifier For Demanding, High-Reliability Applications
Crystek Corporation
June 10, 2008 - Corporate News
Crystek Corp Introduces World’s Smallest High-Performance CRO
Crystek Corporation
May 14, 2008 - Corporate News
Crystek Corporation
April 17, 2008 - Corporate News
New 1260-1400 MHz VCO From Crystek Corporation
Crystek Corporation
October 29, 2007 - Corporate News
Crystek Announces New Distribution Agreement With Digi-Key
Crystek Corporation
October 15, 2007 - Corporate News
Crystek Corporation has signed an agreement with Allied Electronics, a subsidiary of Electrocomponents plc (LSE: ECM), naming Allied as a ...
Crystek Corporation
To find more articles from Crystek Corporation, use the search form below.
