Corporate News Index
May 14, 2008
Rogers Corp. Launches Its E/bak™ Cushion Mounting Materials
Rogers Corporation Launches Its New, Economical E/bak™ Cushion Mounting Materials for Corrugated Printing at Drupa
GENT, Belgium – Rogers Corporation (NYSE:ROG) will introduce its new line of E/bak™ cushion mounting materials, an economically priced cushioning solution for corrugated post-print applications at the 2008 Drupa Show in Dusseldorf, Germany, May 29 – June 11 (Hall 4, Stand 4E60).
E/bak Cushions, based on Rogers’ proven open-cell urethane foam technology, are used to build thickness on the cylinder, as well as provide cushioning and absorb vibration in the corrugated printing process. These resilient cushions provide a high degree of surface conformity with minimal increase in plate pressure.
According to Brett Kilhenny, R/bak Business Manager, Rogers Corporation, “E/bak Cushions are the economic alternative for corrugated printing applications”. Designed to handle easily, E/bak Cushions allow for printing on rough surfaces while eliminating gear banding and press bounce. Added benefits also include decreasing plate wear and increasing plate life while reducing fluting and board crush at increased line speeds. This value performance corrugated cushion continues to provide standard quality print results, lower dot gain, and maintains high solid ink density, allowing for consistent print results over the entire press run. They reduce operating costs by helping to eliminate problems on press with fewer press adjustments.
E/bak SF (supported firm) material is designed on 0.010” PET (0.254mm) film carrier and is cast to thickness, not buffed. This polyester support layer ensures dimensional stability and acts as a mounting base. The foam is dark green in color and has a skin surface. It is available in three standard thicknesses - 0.040” (1.02mm), 0.060” (1.52mm), and 0.080” (2.03mm) - and produced 60 inches (1524mm) wide. Designed for use on general purpose corrugated applications of line and solid work with some simple combination screens, E/bak Cushions are the alternative cushion for mid-range print quality jobs.
Rogers’ E/bak materials are available worldwide through an extensive network of knowledgeable distributors. For more information, please visit http://www.rogerscorporation.com/rbak.
Rogers Corporation
This page has been viewed 294 times.
More from Rogers Corporation
December 9, 2009 - Corporate News
Rogers Introduces Poron Thinstik Soft Seal Foam Material
Rogers Corporation
October 14, 2009 - Corporate News
Rogers Corp. To Showcase Innovative Advanced Materials at Productronica
Rogers Corporation
September 15, 2009 - Corporate News
Rogers Corp Announces Introduction of RO4360 6.15 DK Laminates
Rogers Corporation
August 27, 2009 - Corporate News
Rogers Corp.To Display High Frequency Laminates at IPC Midwest & PCB West Shows
Rogers Corporation
July 24, 2009 - Corporate News
Rogers Corp. New RO4730 Laminates For Light, Low-Loss Antenna Designs
Rogers Corp.
May 13, 2009 - Corporate News
Rogers To Highlight Breakthrough UL Rating, Advanced Thermal Solutions at PCIM
Rogers Corporation
May 12, 2009 - Corporate News
Rogers Introduces Low-Z Axis Material For Airborne Antenna Applications
Rogers Corporation
May 11, 2009 - Corporate News
Rogers to Introduce New Product & Showcase HF Laminates at IEEE MTT-S
Rogers Corporation
May 8, 2009 - Corporate News
Rogers High Performance Foams Division To Highlight 2 Key Products At SAMPE
Rogers Corporation
May 5, 2009 - Corporate News
Rogers Corp Showcases High Frequency Laminates at Del Mar Electronics Show
Rogers Corporation
April 23, 2009 - Corporate News
Rogers Corporation To Showcase High Frequency Laminates at PCB East
Rogers Corporation
April 9, 2009 - Corporate News
Rogers New RT/DUROID Laminates Wins New Product Award
Rogers Corporation
April 8, 2009 - Corporate News
Rogers Introduces RO4000 LoPro Laminates
Rogers Corporation
April 7, 2009 - Corporate News
Rogers To Feature Printed Electronics, Illuminated Advertising Solutions at Printed Electronics
Rogers Corporation
March 30, 2009 - Corporate News
Rogers Corporation To Showcase High Frequency Laminates At CTIA 2009
Rogers Corporation
March 17, 2009 - Corporate News
Rogers Corporation Showcases High Frequency Laminates At IPC APEX EXPO
Rogers Corporation
February 26, 2009 - Corporate News
Rogers To Feature Advanced Circuit Materials At iMAPS Conference & Exhibition
Rogers Corporation
February 25, 2009 - Corporate News
Rogers Corp. to Showcase High Frequency Laminates at Satellite 2009 EXPO
Rogers Corporation
February 10, 2009 - Corporate News
Rogers Issues New Selection Guide for its Bisco Silicone Materials
Rogers Corporation
December 10, 2008 - Corporate News
Rogers Corporation Issues Patent Infringement Complaint
Rogers Corporation
September 18, 2008 - Corporate News
Rogers Featrues Antenna Grade Materials at Antenna Show
Rogers Corporation
September 12, 2008 - Corporate News
Roger's Bisco L3-A Silicone on Track for INNOTRANS
Rogers Corporation
May 28, 2008 - Corporate News
IT Will be Rogers' World at MTT-S Atlanta
Rogers Corporation
May 14, 2008 - Corporate News
Rogers Corporation
May 6, 2008 - Corporate News
Rogers Corp. Features R/bak SA 3000 Cushion Mounting Tapes
Rogers Corporation
To find more articles from Rogers Corporation, use the search form below.
