Corporate News Index
May 13, 2008
Littelfuse Introduces Silicon Overvoltage Protection Array
for Broadband Communication Lines and Interfaces
SP03-6 provides higher surge rating and better clamping than competing devices, and a multi-element design that lowers capacitive losses compared to TVS devices alone.
DES PLAINES, IL - Littelfuse, Inc. (NASDAQ/NGS:LFUS) today announced a new type of overvoltage suppression device for data lines and interface circuits in Ethernet, T3/E3, DS3, ADSL2+, and VDSL2+ systems. The SP03-6 combines a transient voltage suppression (TVS) device with a diode rectifier bridge to provide both longitudinal (common mode) and differential protection in one package, suppressing both positive and negative voltage surges. This design innovation results in low insertion loss and a log-linear capacitive loading characteristic with respect to the signal voltage across the device. The result is reduced intermodulation (IM) distortion compared to typical solid-state protection solutions for high-speed data lines.
The SP03-6 has a reverse standoff voltage of 6V, and clamps surges to 15V under 50A surge current conditions (20V at 100A surge). Its peak surge rating is 150A or 2800W (8/20µs waveform). A low clamping voltage for both common mode and differential surge conditions means there is less stress on the protected equipment, and more robust equipment equates to longer life. Input capacitance at 1MHz is typically 16pF (25pF max.), resulting in low attenuation and better line balance for high-speed data. The SP03-6 meets the requirements of the following standards:
  • IEC 61000-4-5: (Lightning) 150A (8/20µs waveform)
  • Bellcore GR1089: (Intra-Building) 100A (2/10µs waveform)
  • ITU K.20: Ipp =40A (5/310µs waveform)
  • IEC 61000-4-2: (ESD) 15kV (air), 8kV (contact)
  • RoHS (Restrictions On Hazardous Substances) compliance
Availability.
The SP03-6 is available in SO-8 (MS 012) Surface Mount Packaging. OEM samples are available from stock. Tape and reel orders typically ship 8-10 weeks ARO, and come in reel pack quantities of 2500 for efficient, low-cost circuit board installation.
For More Information on the SP03-6 and any of the Littelfuse broadband circuit protection products, or other overvoltage and overcurrent protection devices, visit the Littelfuse website at http://www.littelfuse.com or call the Littelfuse Technical Support line at 1-800-999-9445.
Littelfuse, Inc.
Dan Stanek
This page has been viewed 140 times.
More from Littelfuse, Inc.
YESTech
IPC
Agilent Technologies Announce Additional In-Circuit Test Capacity at Solution Sources
XDry Corporation
PROMATION, Inc.
A.C.E. Production Tech Opens Selective Soldering Process Development Lab
Cobar
Krayden
Pennies Well Spent
PULS UK
ZESTRON America
DYMAX Corporation
Fine Line Stencil
Reed Exhibitions
AVX Corporation
Littelfuse
CheckSum
Orbotech Ltd.
Essemtec
IPC
CheckSum
Federal Electronics
Crystek Corporation
SchmartBoard
KIC
To find more articles from Littelfuse, Inc., use the search form below.
