Home  I  Site Map  I  News  I  Corporate News  I  Exclusives  I  Experts  I  Equipment  I  Directory  I  Calendar
  Corporate News Index
May 8, 2008
New Conformal Coating from DYMAX Meets Requirements
MIL-I-46058C and IPC-CC-830B
DYMAX Corporation, the leader in light-curing technology for electronic materials, announces that Conformal Coating Multi-Cure® 987 has met the requirements of MIL-I-46058C and IPC-CC-830B. Multi-Cure 987 is specifically formulated for rapid room temperature cure when exposed to UV and/or visible light. Any coating in shadowed areas on densely populated circuit boards may be cured with heat. Based on DYMAX Multi-Cure® 984-LVUF, 987 is designed with better wetting on circuitry and components. This product dispenses easily and cures quickly for precise quantity and placement.
Multi-Cure 987 is blue fluorescing under “black” light for easy inspection, and is chemically resistant for better protection. The viscosity is optimal for spraying thin coatings of 0.001 – 0.003" thickness.
DYMAX coatings contain no non-reactive solvents and cure only upon exposure to UV and/or visible light and/or heat. Their ability to cure in seconds enables faster processing, greater output, and lower assembly costs.
DYMAX Corporation is a technology-based company specializing in the formulation, manufacture and service of advanced assembly adhesives, coatings, epoxies, masking resins, and light curing systems.
DYMAX Corporation
http://www.dymax.com/
This page has been viewed 165 times.
More from DYMAX Corporation
September 26, 2008 - Corporate News
DYMAX Corporation
New Moisture-Resistant Gasketing Resin from DYMAX
DYMAX Corporation
DYMAX Corporation
July 14, 2008 - Corporate News
DYMAX Introduces Fluorescing Light-Curing Needle Bonding Adhesive
DYMAX Corporation
July 11, 2008 - Corporate News
Fluorescing Light-Curing Needle Bonding Adhesive from Dymax
DYMAX Corporation
June 6, 2008 - Corporate News
New Conformal Coating from DYMAX Meets MIL-I-46058C and IPC-CC-830B Requirements
DYMAX Corporation
May 30, 2008 - Corporate News
Dymax Partners With Partner PAK
DYMAX Corporation
May 29, 2008 - Corporate News
New DYMAX BlueWaveTM LED System
DYMAX Corporation
May 8, 2008 - Corporate News
DYMAX Corporation
May 6, 2008 - Corporate News
Mr. Terrence Woldorf Joins DYMAX Corporation's Sales and Marketing Team
DYMAX Corporation
April 14, 2008 - Corporate News
Rob Kleinschmidt Joins DYMAX as Sales Engineer
DYMAX Corporation
DYMAX Corporation
March 26, 2008 - Corporate News
DYMAX Corporation
March 25, 2008 - Corporate News
DYMAX Introduces See-CureTM Technology
DYMAX Corporation
March 18, 2008 - Corporate News
DYMAX Release Newest Product Offering for Conformal Coatings
DYMAX Corporation
To find more articles from DYMAX Corporation, use the search form below.
Free Subscription  |   Industry Forums  |   Equipment Mart  |   Exclusives  |   Letters  |   Directory  |   News  |   Site Map  |   Viewpoint  |   White Papers
