May 7, 2008
Areté Optical Systems & RPMC Lasers Enter Marketing Agreement
Areté Optical Systems Research of Longmont, CO, and RPMC Lasers, Inc. of O’Fallon, MO, have entered into a marketing agreement. RPMC will assist in the marketing of Areté’s diode-pumped solid state lasers.
Areté designs, develops, tests, and supports diode pumped solid-state lasers that are more efficient, compact, and reliable than legacy systems. Areté's lasers utilize the latest technology to deliver unprecedented performance and reliability. Areté lasers are designed to operate in difficult mil-spec operational environments where vibration and temperature variation are challenging. The sophisticated on-board diagnostics make Areté lasers well suited for applications in both the laboratory and field.
Areté offers mature lasers with fundamental wavelength (1µm) as well as commonly desired alternative wavelengths, such as 532nm and 1.57µm by utilizing an optical parametric oscillator (OPO). Custom DPSS laser design and development is offered as well.
RPMC Lasers
Chuck Ratermann
http://www.rpmclasers.com
This page has been viewed 99 times. |
More from RPMC Lasers
ZESTRON America
DYMAX Corporation
Fine Line Stencil
Reed Exhibitions
AVX Corporation
Littelfuse
Krayden
CheckSum
Orbotech Ltd.
Essemtec
In a move that will help PCB designers work with greater accuracy and efficiency, IPC — Association Connecting Electronics Industries® has ...
IPC
CheckSum
Federal Electronics
Crystek Corporation
SchmartBoard
KIC
IPC
Vitronics Soltec
SMTA
Manncorp
National Electronics Week
Totech Super Dry
PULS Inrush current limiting
PULS
Humiseal
To find more articles from RPMC Lasers, use the search form below.
