to Synchronize Information Across Design and Manufacturing, Reducing Engineering Change Cycles by Over 75%
Omnify’s Open Integration Platform Enables Direct Data Sharing Between Empower PLM and Epicor® Enterprise Resource Planning Solution
Andover, MA – Omnify Software, a leading provider of product lifecycle management (PLM) software for electronic, medical, mechanical, and defense manufacturers, today announces that Treske Precision Machining, a manufacturer of Precision Machined Parts, Welded Frames, and Integrated Assemblies, selected Omnify Empower as their PLM solution for its ease of use, affordable cost, and open integration platform. Treske has reported a decrease in their engineering change cycles by over 75% by managing all product information within Empower and sharing released data with manufacturing via a direct integration with their Enterprise Resource Planning (ERP) solution from Epicor Software Corporation, Epicor Vantage® 8.0.
A substantial growth in Treske’s customer base and pending ISO certification changed their requirements for managing product information. The company had implemented an ERP solution from Epicor—a global leader delivering enterprise business software solutions to the midmarket and divisions of Global 1000 companies— to manage manufacturing information such as job planning, purchasing, inventory and financial data. Treske knew the best way to manage their growing product information and properly track documentation for ISO certification was to employ a PLM solution. Treske’s ultimate goal was to integrate the ERP and PLM environments to directly share information through an automated process and eliminate double entry of part data.
“As we searched for a PLM solution, one of the key requirements was that it needed to integrate with our Epicor ERP solution,” said Mark Brenden, engineering manager for Treske Precision Machining. “Omnify provided a straightforward PLM solution that was intuitive, extremely easy to use, affordable, and offered the capability to integrate with our ERP solution that other PLM vendors could not deliver. Omnify also provided an excellent support team that understood our needs which made them our number one choice. We could not be without their PLM solution today.”
Omnify Empower is now the master control database for all system and product documentation at Treske. With Empower, Treske has a single system to manage their 20,000 plus part numbers and associated prints. Centralized storage for all product documentation with revision control, part association and controlled editing helps Treske to comply with ISO standards and facilitate their requirements to receive certification.
Epicor Service Connect coupled with Omnify’s open integration platform provided an easy integration process. With the integration to Epicor, engineering does not have to manually enter information in two locations. When engineering releases a part or ECO (Engineering Change Order) from Omnify Empower, it is automatically uploaded to the Epicor ERP system. Planners can then create a method for manufacturing, approve a revision, and generate a job within Epicor. Sharing data between Omnify and Epicor through an automated process has allowed Treske to reduce ECO cycles by eliminating the introduction of errors due to manual entry of BOMs and ensuring planners have correct and current information within the ERP solution. “Our overall ECO processing time has been reduced by more than 75%,” stated Mr. Brenden.
“Our open integration platform enables customers to easily share data with their existing engineering and manufacturing systems through an automated process,” stated Chuck Cimalore, CTO for Omnify Software. “Innovative customers like Treske who integrate Omnify with their ERP environment are able to eliminate error-prone manual data entry processes and synchronize information across the enterprise to guarantee that all departments have access to current and accurate product data.”
September 2, 2010 - Corporate News
Enthone Introduces ENTEK® OM
Enthone Inc. has introduced ENTEK® OM. The patented, Organic Metal® process delivers a visible, highly conductive PWB final finish that ...
Enthone Inc.
Juki Donates a KE-760 Flexible Placement System to 'Industrial Strength' Equipment Charity Auction
Juki
DYMAX President Appointed to Manufacturing Council
DYMAX
BTU to Highlight Next Gen Thermal Processing Capabilities at EUPVSEC
BTU International
Electrolube Introduces its New Reflow Oven Cleaner at ATE Chicago
Electrolube
ASSET enhances boundary-scan test capabilities on ScanWorks platform for embedded instruments
ASSET® InterTech
NEPCON South China 2010 Kicks Off With Strong Start
Reed Exhibitions
iNETest Technologies India to Showcase BPM Microsystems’ Universal Device Programmer at Electronica/Productronica India
BPM Microsystems
September 1, 2010 - Corporate News
DYMAX Conformal Coating 9481 Mitigates Tin Whisker Formation
DYMAX Dual-Cure 9481 cures in seconds to protect delicate circuitry on tin solder joints. Conformal coatings are recommended for retarding ...
DYMAX Corporation
Manncorp Revamps Entire Line of Rework Systems
Manncorp
Ellsworth Adhesives Launches New Website in Finland
Ellsworth Adhesives
For the Cleanest Boards in the Midwest, Come See Kyzen's AQUANOX® A4703 at IPC Electronics Midwest
Kyzen Corporation
Juki to Debut Innovative Assembly Systems at IPC Electronics Midwest
Juki Corporation
Seika Releases Latest Features for McDry Electronic Drying Storage Cases
Seika Machinery, Inc.
Virtual Ind. to Showcase Vacuum Handling Solutions at IPC Electronics Midwest
Virtual Industries Inc. announces that it will showcase several advanced vacuum tweezer systems in booth 1045 at the upcoming IPC Electronics ...
IPC Conference in Budapest Offers Critical Info on Quality, Reliability
Eastern Europe's growing electronics assembly industry faces new challenges, especially with the adoption of lead-free technology. To ...
IPC
Everett Charles Techs' Contact Products Group Appoints Global Sales Director
Everett Charles Technologies' Contact Products Group (CPG) is announces the creation of a new Global Sales Director position and has selected ...
DfR Solutions Announces Austin Design for Excellence (DfX) Seminar
August 31, 2010 - Corporate News
Aqueous Technologies to Feature Cleaning Equipment at IPC Electronics Midwest
Microscreen Adds Second Exposure Room for Thick Film Screens
Microscreen
ICON Technologies Celebrates 5-Year Anniversary
ICON Technologies announces its five-year anniversary. With its' indirect sales channels, ICON offers an extremely cost-effective and proven ...
ICON Technologies
Bare Board Group Receives 4th Consecutive Placement on the Inc 5000 List
Bare Board Group
BPM Microsystems Introduces 8th Generation Universal Programming System
BPM Microsystems
RMD Instruments to Discuss How to Improve Supply Chain Reliability with XRF Technology at PCB West
RMD Instruments Corp.
P. D. Circuits' Mike Tucker to Present at PCB West 2010
P. D. Circuits, Inc. announces that Mike Tucker, Technical Service Engineer, will hold a presentation titled “A Look At CAM Departments ...
