for Luxury Car Manufacturer
SANTA ANA, Calif. - ITT Interconnect Solutions, a leading global manufacturer and supplier of connectors, interconnects, and cable assemblies, has developed a miniature circular connector solution. Designated the KPTC Series, the backshell connector provides high contact density in a rugged metal shell and was originally developed for a luxury car manufacturer and an associated subcontractor to accommodate specific harnessing requirements within automotive diagnostic equipment.
"Leveraging a strong sourcing capability in Asia, robust product engineering and industry leading lean manufacturing capabilities, we were able to develop a custom backshell solution to meet both the specifications and price targets of our customer," said Keith Teichmann, director of marketing for ITT Interconnect Solutions.
"The design of the KPTC Series connectors also makes them ideal for use in industrial machinery, motion control, power generators, engine control, and mobile phone base stations, along with multi-signal specialty harnessing integration."
The KPTC Series connector is capable of integrating custom harnessing rigs and a wide range of wire gauges. Additional features include IP67 sealing and gold plated contacts, allowing the connector to withstand harsh environments, as well as bayonet coupling for quick and simple mating and unmating. A shielded endbell is available for fast assembly.
Offered in size 20 and size 16 contacts, the KPTC Series connector features a lifespan to at least 500 mating cycles. Contact current rating at 20°C is 7.5A for the size 20 connector and 22A for the size 16 connector. Contact resistance is 14.7mohms and 3.8mohms, respectively.
Typical pricing for the KPTC Series circular connector ranges from approximately $23 to $26 each. Lead time is 6 weeks.
