April 23, 2008
Let Us Spray – ESD Coating From Intertronics
Static dissipative coatings just get better and better – and this Licron Crystal spray-on urethane from Intertronics is user applicable and permanent. Produced by Techspray, Licron Crystal is described as a revolutionary and innovative concept in permanent static dissipative coatings – it is a versatile, crystal clear urethane coating that adheres to metal, plastic and most other surfaces. This makes it ideal for converting standard boxes, bins, tools and other surfaces to ESD-safe, saving expensive replacement cost. The end result is compliant with ANSI/ESD-S20.20, which prevents static damage to sensitive electronic components. Applications include electronic assembly workstations and enclosures, component packaging, conveyors and electronic devices themselves.
Peter Swanson, M.D. at Intertronics, explained: “This is an excellent product in so many ways – not only can users self-apply to virtually their whole work area using aerosol, standard spray gun or other paint systems – it also leaves a clear non-chipping ESD-safe surface that maintains 107 to 109 ohms resistivity.”
Licron Crystal operates independently of humidity and leaves a surface that can be simply grounded by wire attachment in a similar way to any normal ESD floor. Further information regarding Intertronics’ products can be found at www.intertronics.co.uk.
Intertronics
Peter Swanson
http://www.intertronics.co.uk
This page has been viewed 254 times. |
More from Intertronics
December 23, 2008 - Corporate News
Intertronics Have The Answers!
Intertronics
December 2, 2008 - Corporate News
Light Enhancing, Heat Dissipating Silicones From Intertronics
Intertronics
November 24, 2008 - Corporate News
Intertronics Moves Conformal Coating Ahead Of The Game
Intertronics
October 29, 2008 - Corporate News
'They Nail Horses Shoes – Don’t They?' Asks Intertronics
Intertronics
October 8, 2008 - Corporate News
Into The Blue!
Intertronics
September 29, 2008 - Corporate News
Dymax Bluewave® Led System Now CE Marked From Intertronics
Intertronics
September 18, 2008 - Corporate News
Intertronics – Fine Mist Lubricant System
Intertronics
Free Visual Guide – Adhesive Dispensing Made Easy
Intertronics
August 7, 2008 - Corporate News
Unique Boutique Clock Has UV Adhesive Solution
Intertronics
July 17, 2008 - Corporate News
“Adhere” Launches Premier Cyanoacrylate “Instant” Adhesive
Intertronics
June 12, 2008 - Corporate News
"Adhere" "Star" Product In Araldite 2000 Plus Range
Intertronics
May 19, 2008 - Corporate News
RFID Tag Bonding – Intertronics Addresses Harsh Supply Chain Applications
Intertronics
April 23, 2008 - Corporate News
Intertronics
February 29, 2008 - Corporate News
Super Light-Weight – Super Performance Dispensing Valve
Intertronics
January 25, 2008 - Corporate News
Improving Industrial Dispensing With Pneumatic Valves
Intertronics
To find more articles from Intertronics, use the search form below.
