LITTLETON, MASS. - VJ Electronix, the leader in X-Ray inspection technology and Rework systems, announces that it has been awarded a NPI Award in the category of Test & Inspection, AXI for its Vertex Series-A X-Ray Inspection System. The award was presented to the company during a Monday, March 31, 2008 ceremony that took place in the Mandalay Bay Resort & Convention Center in Las Vegas before the start of APEX 2008.
To meet significant industry challenges, the Vertex Series-A X-Ray Inspection System offers numerous features to help customers to inspect PCB and component assemblies quickly and accurately. A new flexible design allows it to be customized to any Inspection Task.
The Vertex Series-A allows for faster load/unload product exchange; reproducible results based on repeatability of precision, programmable control system.
The Vertex Series-A offers an inspectable area of 508 x 610 mm (20 x 24”) with 100 percent coverage. The large board-handling table and large inspection area are especially important to suit server boards and other large assemblies. Its modular configuration allows customers to select multiple choices of x-ray sources, detectors and motion components as well as Software Options to optimize the system for any application. Automation of the Vertex Series-A allows one operator to run multiple machines. Also, the large sample tray means multiple small to medium sized assemblies can be loaded at the same time.
The Vertex Series-A is production-ready. Because the system is designed for the production floor, its small footprint allows X-ray capabilities to be used in a space no greater than a conventional AOI machine. For Product traceability it provides Ports to accept Barcode Readers. It utilizes a variety of Smart Tubes, which automatically control start-up procedures for minimum operator interaction and maximum tube life
The ergonomic design of the Vertex Series-A offers an adjustable operator console, sliding door, large window and easy sample loading. With the table moved next to the Door, heavier assemblies may be loaded into the machine with minimal physical effort. Additionally, the system is easy to use because it provides on-board navigation using a camera to map inspection locations, a simplified GUI that allows easy setting or changing of X-ray parameters, local language support, 1-2 GO (place sample-select program-Go), automated stored inspection sequences, and export of inspection data to other systems. The use of sealed X-Ray tubes minimizes the maintenance efforts and the whole system is designed to be maintenance and service friendly.
Premiering in 2008, the NPI Awards program is an annual celebration of product excellence in electronics surface mount assembly. Premier products based on the finest examples of creative advancement in technology are chosen by a distinguished panel of industry experts.
