April 16, 2008
Get Cool, Consistent, Visible Light Curing with New DYMAX BlueWaveTM LED System
The new BlueWave™ LED visible light, high-intensity spot curing system from DYMAX Corporation offers many advantages over traditional UV spot curing systems including… no bulbs to change, cool cures, no warm-up, and constant intensity for thousands of hours. The BlueWave LED generates light using an array of surface mount LEDs (Light Emitting Diodes) instead of traditional metal halide or mercury bulbs. The LEDs produce visible light energy in a relatively narrow wavelength band centered at 410 nm, as contrasted to a typical broad band, high-pressure UV bulb (300-500 nm). This system emits a maximum visible light intensity output of over 2,500 mW/cm2 from an 8 mm diameter lightguide, and allows users to adjust intensity output from 0% to 100%. The relatively narrow band produced by LEDs generates cooler curing temperatures. The BlueWave LED is excellent for spot curing of coatings, as well as adhesive bonding of polycarbonate, PVC, PET, metal, glass and many other substrates.
The BlueWave LED curing system can cure many of DYMAX’s visible light curing adhesives that are currently being produced. Their Applications Engineering Group can offer adhesive recommendations for assembly processes utilizing the BlueWave LED curing systems.
DYMAX Corporation is a technology-based company specializing in the formulation, manufacture and service of advanced assembly adhesives, coatings, epoxies, masking resins, and UV curing systems.
DYMAX Corp.
Corinne Rebillard
http://www.dymax.com
This page has been viewed 193 times. |
More from DYMAX Corp.
January 6, 2009 - Corporate News
Ken Morton Joins Tridak as Dispense Systems Engineer
Tridak
December 16, 2008 - Corporate News
Dispensing Leader Tridak is Acquired by DYMAX
DYMAX
December 10, 2008 - Corporate News
DYMAX + PARTNER PAK = Sustainable Clamshell Packaging Technology for Electronics
DYMAX
December 1, 2008 - Corporate News
Dymax Debuts New, Highly Functional Website
Dymax Corporation
November 26, 2008 - Corporate News
DYMAX Plastics Bonding Adhesive Has Built-in Cure Indicator
DYMAX
DYMAX Corporation
November 13, 2008 - Corporate News
New Dymax ACCU-CAL™ 50V Visible Radiometer
Dymax Corporation
DYMAX - One of the Fastest-Growing Companies in the U.S.
DYMAX Corporation
October 23, 2008 - Corporate News
DYMAX
October 22, 2008 - Corporate News
DYMAX Plastic-Bonding Adhesives Pair Well with New BlueWave® LED Spot Curing System
DYMAX Corporation
DYMAX Acquires Dispensing Leader Tridak
DYMAX Corporation
September 26, 2008 - Corporate News
DYMAX Corporation
September 25, 2008 - Corporate News
DYMAX
September 24, 2008 - Corporate News
New DYMAX ACCU-CAL™ 50V Visible Radiometer
DYMAX
DYMAX
New Moisture-Resistant Gasketing Resin from DYMAX
DYMAX Corporation
July 28, 2008 - Corporate News
DYMAX BlueWave LED System Now CE Marked for Global Distribution
DYMAX
DYMAX Corporation
July 14, 2008 - Corporate News
DYMAX Introduces Fluorescing Light-Curing Needle Bonding Adhesive
DYMAX Corporation
July 11, 2008 - Corporate News
Fluorescing Light-Curing Needle Bonding Adhesive from Dymax
DYMAX Corporation
June 6, 2008 - Corporate News
New Conformal Coating from DYMAX Meets MIL-I-46058C and IPC-CC-830B Requirements
DYMAX Corporation
May 8, 2008 - Corporate News
New Conformal Coating from DYMAX Meets Requirements
DYMAX Corporation
May 7, 2008 - Corporate News
Mr. Kyle Rhodes Joins DYMAX as Medical Market Segment Manager
Dymax
May 6, 2008 - Corporate News
Mr. Terrence Woldorf Joins DYMAX Corporation's Sales and Marketing Team
DYMAX Corporation
April 16, 2008 - Corporate News
DYMAX Corp.
To find more articles from DYMAX Corp., use the search form below.
