April 15, 2008
180° Curing w/ New DYMAX UVCS SideCure™ Conveyor System
When the job calls for 180° curing, the new DYMAX UVCS SideCure™ conveyor system is the equipment you need! Designed for UV curing of DYMAX adhesives and coatings from the left, right, and/or top, the SideCure conveyor can be outfitted with up to eight DYMAX 5000-EC UV curing flood lamps. The conveyor’s 12" wide belt and 7.5" vertical clearance, with 5" high side-curing capability, allows for the curing of large parts and makes the SideCure a very versatile UV curing solution. In addition, the relatively small conveyor size – 51" x 30" x 21.5" – minimizes the footprint required for UV curing. The use of the DYMAX SideCure conveyor system can often eliminate potential “shadowed areas” around components that are detrimental to a light curing process.
The high-intensity DYMAX 5000-EC lamps used with the UVCS SideCure conveyor provide 225 mW/cm2 of intensity for fast UV curing as well as complete shielding from UV light and consistent exposure times. The SideCure conveyor can be outfitted with up to four 5000-EC lamps on top and up to four 5000-EC lamps on the sides. When 5000-EC lamps are configured in series, the conveyor belt speeds can often be doubled.
The SideCure conveyor system is ideal for bonding, masking, and coating applications in the medical, electronic, industrial, and aerospace industries where 180° UV curing is required.
DYMAX Corporation is a technology-based company specializing in the formulation, manufacture and service of advanced assembly adhesives, coatings, epoxies, masking resins, and UV curing systems.
DYMAX Corp.
Corinne Rebillard
http://www.dymax.com
This page has been viewed 214 times. |
More from DYMAX Corp.
January 6, 2009 - Corporate News
Ken Morton Joins Tridak as Dispense Systems Engineer
Tridak
December 16, 2008 - Corporate News
Dispensing Leader Tridak is Acquired by DYMAX
DYMAX
December 10, 2008 - Corporate News
DYMAX + PARTNER PAK = Sustainable Clamshell Packaging Technology for Electronics
DYMAX
December 1, 2008 - Corporate News
Dymax Debuts New, Highly Functional Website
Dymax Corporation
November 26, 2008 - Corporate News
DYMAX Plastics Bonding Adhesive Has Built-in Cure Indicator
DYMAX
DYMAX Corporation
November 13, 2008 - Corporate News
New Dymax ACCU-CAL™ 50V Visible Radiometer
Dymax Corporation
DYMAX - One of the Fastest-Growing Companies in the U.S.
DYMAX Corporation
October 23, 2008 - Corporate News
DYMAX
October 22, 2008 - Corporate News
DYMAX Plastic-Bonding Adhesives Pair Well with New BlueWave® LED Spot Curing System
DYMAX Corporation
DYMAX Acquires Dispensing Leader Tridak
DYMAX Corporation
September 26, 2008 - Corporate News
DYMAX Corporation
September 25, 2008 - Corporate News
DYMAX
September 24, 2008 - Corporate News
New DYMAX ACCU-CAL™ 50V Visible Radiometer
DYMAX
DYMAX
New Moisture-Resistant Gasketing Resin from DYMAX
DYMAX Corporation
July 28, 2008 - Corporate News
DYMAX BlueWave LED System Now CE Marked for Global Distribution
DYMAX
DYMAX Corporation
July 14, 2008 - Corporate News
DYMAX Introduces Fluorescing Light-Curing Needle Bonding Adhesive
DYMAX Corporation
July 11, 2008 - Corporate News
Fluorescing Light-Curing Needle Bonding Adhesive from Dymax
DYMAX Corporation
June 6, 2008 - Corporate News
New Conformal Coating from DYMAX Meets MIL-I-46058C and IPC-CC-830B Requirements
DYMAX Corporation
May 8, 2008 - Corporate News
New Conformal Coating from DYMAX Meets Requirements
DYMAX Corporation
May 7, 2008 - Corporate News
Mr. Kyle Rhodes Joins DYMAX as Medical Market Segment Manager
Dymax
May 6, 2008 - Corporate News
Mr. Terrence Woldorf Joins DYMAX Corporation's Sales and Marketing Team
DYMAX Corporation
April 16, 2008 - Corporate News
Get Cool, Consistent, Visible Light Curing with New DYMAX BlueWaveTM LED System
DYMAX Corp.
To find more articles from DYMAX Corp., use the search form below.
