Corporate News Index
April 11, 2008
Aqueous Technologies’ Trident Automatic Defluxing System Named as a Two-Time First Finalist for the VISION Awards
RANCHO CUCAMONGA, CA — Aqueous Technologies Corp. announces that Trident, its fourth-generation automatic defluxing system, was named as a first finalist in both the Cleaning Systems and Environmentally Friendly Products/Services categories during the VISION Awards announcement ceremony that took place Wednesday, April 2, 2008 in Las Vegas during APEX 2008. The Trident Series represents the next generation of lead-free compatible, fully automatic post-reflow defluxing systems.
Now in its 16th year, the SMT VISION Awards program is an annual celebration of product excellence in electronics surface mount assembly. Premier products based on the finest examples of creative advancement in technology in 16 key areas are chosen by a distinguished panel of industry experts.
http://www.aqueoustech.com/
This page has been viewed 168 times.
More from Aqueous Technologies
Aqueous to Highlight the Trident Automatic Defluxing System at IPC Midwest
August 26, 2008 - Corporate News
Aqueous Technologies’ Trident Automatic Defluxing System Wins a 2008 Global Technology Award
Aqueous Technologies to Debut the SMT3000LD Automatic Defluxing System at Nepcon South China
August 5, 2008 - Corporate News
Aqueous Technologies to Debut the Trident III Automatic Defluxing System at SMTAI
Aqueous Technologies Trident Automatic Defluxing System Wins Two 2008 Advanced Packaging Awards
May 19, 2008 - Corporate News
Aqueous Technologies to Premier the Trident Automatic Defluxing System at SMT Nuremberg
May 8, 2008 - Corporate News
Aqueous Technologies Introduces New Financing Offer
April 21, 2008 - Corporate News
Aqueous Technologies Wins an EMAsia Innovation Award
Aqueous Technologies C3 Cleanliness Tester Wins VISION Award
April 11, 2008 - Corporate News
April 9, 2008 - Corporate News
Aqueous Wins Industry Award for Its Trident Automatic Defluxing System
Aqueous Technologies to Display Zero-Ion Contamination Tester at APEX
March 25, 2008 - Corporate News
Aqueous Tech to Showcase Trident Automatic Defluxing Systems at APEX
March 24, 2008 - Corporate News
Aqueous Technologies to Highlight StencilWasher-ECO at APEX
March 18, 2008 - Corporate News
Aqueous Technologies to Feature C3 Cleanliness Tester at APEX
March 12, 2008 - Corporate News
Aqueous Technologies to Display StencilWasher-CLR at APEX
January 8, 2008 - Corporate News
Aqueous Technologies Appoint Accelonix as Distributor
January 3, 2008 - Corporate News
Aqueous Announces 3rd Installment in E-Learning Presentation
To find more articles from Aqueous Technologies, use the search form below.
