RANCHO CUCAMONGA, CA — Aqueous Technologies Corp. announces that it has been awarded a NPI Award in the category of Cleaning Equipment for Trident, its fourth-generation automatic defluxing system. The award was presented to the company during a Monday, March 31, 2008 ceremony that took place in the Mandalay Bay Resort & Convention Center in Las Vegas before the start of APEX 2008. The Trident Series represents the next generation of lead-free compatible, fully automatic post-reflow defluxing systems.
Premiering in 2008, the NPI Awards program is an annual celebration of product excellence in electronics surface mount assembly. Premier products based on the finest examples of creative advancement in technology are chosen by a distinguished panel of industry experts.
