NASHVILLE — Kyzen Corporation, a world leading provider of environmentally responsible precision cleaning chemicals, announces that it will showcase Metalnox M6319 in booth 550 at the upcoming MetalForm Exhibition and Conference scheduled to take place April 1-3, 2008, at the Birmingham-Jefferson Convention Complex in Birmingham, AL.
Metalnox M6319 is a heavy-duty aqueous high alkaline all-purpose cleaner. It is an aqueous blend of detergents, alkalinity builders, conditioners, and organic and inorganic inhibitors designed for heavy-duty cleaning of oils, waxes, grease, drawing oils, machining oils, fingerprints, hydraulic fluids, road dirt, carbonized oils, petrolatum and shop dirt while being relatively safe to use on most alloys.
M6319 is easy to use, and is diluted further with water as required to remove the soils involved. To prevent flash rusting of ferrous parts, 1 to 3 percent of M6319 or an inhibitor may be added to all rinse stages.
The cleaner is low foaming, non-phosphated, and is safe on magnesium as well as ferrious and copper alloys. It features trace silicates, prevents flash rust, and has no HAPs, CFCs or SARA 313s. Additionally, M6319 features low-use cost and is low VOC. The cleaner can be used in both spray and immersion systems.
M6319 is multi-metal safe for use on yellow metals including copper, bronze and brass, some aluminum alloys, iron, steel, and composites in addition to most precious metals, plastics and rubbers. The cleaner is available commercially in one, five and 55 gallon containers.
