Vertex Series-A Audit X-Ray System at APEX>
Corporate News Index
March 27, 2008
VJ Electronix to Highlight the Vertex Series-A Audit X-Ray System at APEX
LITTLETON, MASS. - VJ Electronix, the leader in X-Ray inspection technology and Rework systems, announces that it will showcase Vertex Series-A X-Ray Inspection System in booth 648 at the upcoming IPC APEX exhibition and designers summit, scheduled to take place April 1-3, 2008, in Las Vegas, NV.
To meet significant industry challenges, the Vertex Series-A X-Ray Inspection System offers numerous features to help customers to inspect PCB and component assemblies quickly and accurately. A new Flexible Design allows it to be customized to any Inspection Task. The Vertex Series-A allows for faster load/unload product exchange; reproducible results based on repeatability of closed-loop control system.
The Vertex Series-A offers an inspectable area of 508 x 610 mm (20 x 24") with 100% coverage. The large board-handling table and large inspection area are especially important to suit server boards and other large assemblies. Its modular configuration allows customers to select multiple choices of x-ray source, detector and motion components as well as Software Options to optimize the system for any application. Automation of the Vertex Series-A allows one operator to run multiple machines. Also, the large sample tray means multiple small to medium sized assemblies can be loaded at the same time.
The Vertex Series-A is production-ready. Because the system is designed for the production floor, its small footprint allows X-ray capabilities to be used in a space no greater than a conventional AOI machine. For Product traceability it provides Ports to accept Barcode Readers
The ergonomic design of the Vertex Series-A offers an adjustable operator console, sliding door, large window and easy sample loading. With the table moved next to the Door, heavier assemblies may be loaded into the machine with minimal physical effort. Additionally, the system is easy to use because it provides on-board navigation using a camera to map inspection locations, a simplified GUI that allows easy setting or changing of X-ray parameters, local language support, 1-2 GO (place sample-select program-Go), automated stored inspection sequences, and export of inspection data to other systems. The use of sealed X-Ray tubes minimizes the maintenance efforts and the whole system is designed to be maintenance and service friendly.
VJ Electronix
http://www.vjelectronix.com
This page has been viewed 58 times.
More from VJ Electronix
ZESTRON America
DYMAX Corporation
Fine Line Stencil
Reed Exhibitions
AVX Corporation
Littelfuse
Krayden
CheckSum
Orbotech Ltd.
Essemtec
IPC
CheckSum
Federal Electronics
Crystek Corporation
SchmartBoard
KIC
IPC
Vitronics Soltec
SMTA
Manncorp
National Electronics Week
Totech Super Dry
PULS Inrush current limiting
PULS
Humiseal
To find more articles from VJ Electronix, use the search form below.
