Corporate News Index
March 25, 2008
DYMAX Introduces See-CureTM Technology
See it Dispense. See it Cure. See the Solution.
If to see is to believe, then DYMAX has developed the world's most persuasive light-curing adhesive technology for industrial assembly processes. See-Cure™ technology addresses the two most-often asked questions about light-curing products: How do I know I've dispensed enough adhesive? and How do I know when it is cured?
DYMAX adhesives that are formulated with new See-Cure technology are bright blue in color in the uncured condition. This makes them easy to see on the surface of substrates, in deep wells, or when sandwiched between two layers of materials. The blue-colored See-Cure adhesives will not permanently stain the component surfaces that they contact. Because the blue color is extremely visible, simple vision systems can be incorporated into assembly processes prior to curing in order to easily identify adhesive coverage and profile.
But, See-Cure’s blue color is only temporary!
The adhesive’s blue color becomes the visible indicator that identifies when sufficient light energy has been provided to the adhesive bond area to achieve full cure. As the adhesive cures, the blue color within the adhesive fades and ultimately turns clear upon full cure.
Representative adhesives formulated with See-Cure technology for use in medical device assembly were subjected to biocompatibility testing. It was verified that the addition of DYMAX See-Cure technology has no affect on the biocompatibility rating of the original adhesive product or on the biocompatibility of the component surfaces.
DYMAX Corporation is a technology-based company specializing in the formulation, manufacture and service of advanced assembly adhesives, coatings, epoxies, masking resins, and UV curing systems.
DYMAX Corporation
Corinne Rebillard
http://www.seeitcure.com/
This page has been viewed 219 times.
More from DYMAX Corporation
DYMAX Corporation
November 13, 2008 - Corporate News
New Dymax ACCU-CAL™ 50V Visible Radiometer
Dymax Corporation
DYMAX - One of the Fastest-Growing Companies in the U.S.
DYMAX Corporation
October 23, 2008 - Corporate News
DYMAX + PARTNER PAK = Sustainable Clamshell Packaging Technology
DYMAX
October 22, 2008 - Corporate News
DYMAX Plastic-Bonding Adhesives Pair Well with New BlueWave® LED Spot Curing System
DYMAX Corporation
DYMAX Acquires Dispensing Leader Tridak
DYMAX Corporation
September 26, 2008 - Corporate News
DYMAX Corporation
September 25, 2008 - Corporate News
DYMAX
September 24, 2008 - Corporate News
New DYMAX ACCU-CAL™ 50V Visible Radiometer
DYMAX
DYMAX
New Moisture-Resistant Gasketing Resin from DYMAX
DYMAX Corporation
July 28, 2008 - Corporate News
DYMAX BlueWave LED System Now CE Marked for Global Distribution
DYMAX
DYMAX Corporation
July 14, 2008 - Corporate News
DYMAX Introduces Fluorescing Light-Curing Needle Bonding Adhesive
DYMAX Corporation
July 11, 2008 - Corporate News
Fluorescing Light-Curing Needle Bonding Adhesive from Dymax
DYMAX Corporation
June 6, 2008 - Corporate News
New Conformal Coating from DYMAX Meets MIL-I-46058C and IPC-CC-830B Requirements
DYMAX Corporation
May 8, 2008 - Corporate News
New Conformal Coating from DYMAX Meets Requirements
DYMAX Corporation
May 7, 2008 - Corporate News
Mr. Kyle Rhodes Joins DYMAX as Medical Market Segment Manager
Dymax
May 6, 2008 - Corporate News
Mr. Terrence Woldorf Joins DYMAX Corporation's Sales and Marketing Team
DYMAX Corporation
April 16, 2008 - Corporate News
Get Cool, Consistent, Visible Light Curing with New DYMAX BlueWaveTM LED System
DYMAX Corp.
180° Curing w/ New DYMAX UVCS SideCure™ Conveyor System
DYMAX Corp.
April 14, 2008 - Corporate News
Rob Kleinschmidt Joins DYMAX as Sales Engineer
DYMAX Corporation
April 10, 2008 - Corporate News
Dymax
DYMAX Corporation
March 26, 2008 - Corporate News
DYMAX Corporation
To find more articles from DYMAX Corporation, use the search form below.
