Corporate News Index
March 25, 2008
Aqueous Tech to Showcase Trident Automatic Defluxing Systems at APEX
RANCHO CUCAMONGA, CA — Aqueous Technologies Corp. announces that it will highlight the Trident, its fourth-generation automatic defluxing system, and Trident II in booth 2431 at the upcoming APEX 2008 exhibition and conference scheduled to take place April 1-3, 2008 in Las Vegas. The Trident Series represents the next generation of lead-free compatible, fully automatic post-reflow defluxing systems.
Trident automatic defluxing system is the fastest batch-format defluxing system available. Trident’s specific throughput rate is determined by equipment model and user’s board size. Trident is available in four throughput configurations, the highest is capable of defluxing and cleanliness testing up to 896 4 x 6" (101 x 152 mm) boards and up to 112 18 x 20" (457 x 508 mm) boards per hour.
The most flexible defluxing system available, Trident also offers several defluxing configurations designed to provide complete compatibility with all defluxing requirements. The system’s defluxing process consists of up to five cycles including prewash, wash, rinse, cleanliness testing and drying. Prewash, if selected, may consist of a steam soak, high-pressure DI water spray, or chemical spray and soak. The wash cycle uses environmentally responsible defluxing solutions, neutralizing and solublizing flux and other residues. The rinse cycle is controlled by the built-in cleanliness tester in which rinse cycles are added or subtracted from the process automatically, based on the user’s selected cleanliness requirements. The dry cycle uses a unique combination of radiant and convection heat for rapid, thorough drying.
Also on display during APEX will be the Trident II, which features all the same features as the Trident, but is also capable of removing all flux residues including rosin, no-clean and water soluble. Both lead and lead-free flux residues may be removed using Trident II. Trident II is equipped with a closed-loop wash solution recycling system. Wash solution is heated automatically and sprayed on the assemblies.At the end of the wash cycle, the wash solution is directed back to the wash solution holding tank for subsequent reuse. Rinse water is then sprayed onto the assemblies until the desired cleanliness level is achieved. All rinse water is directed through the pre-drain filtration system then sent to drain.Assemblies are dried via the on-board convection and radiant forced air drying system. An optional Zero-Discharge evaporation system eliminates connection to a drain line.
http://www.aqueoustech.com
This page has been viewed 146 times.
More from Aqueous Technologies
Aqueous to Highlight the Trident Automatic Defluxing System at IPC Midwest
August 26, 2008 - Corporate News
Aqueous Technologies’ Trident Automatic Defluxing System Wins a 2008 Global Technology Award
Aqueous Technologies to Debut the SMT3000LD Automatic Defluxing System at Nepcon South China
August 5, 2008 - Corporate News
Aqueous Technologies to Debut the Trident III Automatic Defluxing System at SMTAI
Aqueous Technologies Trident Automatic Defluxing System Wins Two 2008 Advanced Packaging Awards
May 19, 2008 - Corporate News
Aqueous Technologies to Premier the Trident Automatic Defluxing System at SMT Nuremberg
May 8, 2008 - Corporate News
Aqueous Technologies Introduces New Financing Offer
April 21, 2008 - Corporate News
Aqueous Technologies Wins an EMAsia Innovation Award
Aqueous Technologies C3 Cleanliness Tester Wins VISION Award
April 11, 2008 - Corporate News
Aqueous Technologies’ Trident Automatic Defluxing System Named as a Two-Time First Finalist for the VISION Awards
April 9, 2008 - Corporate News
Aqueous Wins Industry Award for Its Trident Automatic Defluxing System
Aqueous Technologies to Display Zero-Ion Contamination Tester at APEX
March 25, 2008 - Corporate News
March 24, 2008 - Corporate News
Aqueous Technologies to Highlight StencilWasher-ECO at APEX
March 18, 2008 - Corporate News
Aqueous Technologies to Feature C3 Cleanliness Tester at APEX
March 12, 2008 - Corporate News
Aqueous Technologies to Display StencilWasher-CLR at APEX
January 8, 2008 - Corporate News
Aqueous Technologies Appoint Accelonix as Distributor
January 3, 2008 - Corporate News
Aqueous Announces 3rd Installment in E-Learning Presentation
To find more articles from Aqueous Technologies, use the search form below.
