March 17, 2008
Bake for Repair
How much time isrequired to bake a mobile phone PCBA, in order to eliminate the moisture inside, before doing any repair work on thecomponents ona board?
K. L.
This "Ask the Experts" page has been viewed 720 times.
March 24, 2008
Unfortunately, there isn't a simple answer to your question. Let's take a detailed view of your inquiry.
- We will assume that the soldered assembly has been exposed to the factory atmosphere of 30 deg. C/60% RH, for a period that is beyond the acceptable "floor-life" as specified in IPC/JEDEC J-Std 033B. Therefore, the component packages are at risk of moisture-induced damage at solder reflow temperatures, during repair. The PCB itself is less susceptible to MSD at this point.
- We will assume that the solder in use is a "n-Pb" which increases the reflow temperature and the generated internal pressure.
At this point, you can elect to use the default baking schedule specified by J-Std-033B which is 125 deg. C for 48 hours. This schedule is safe to assume to remove sufficient ingested moisture from the surface-mounted packages to prevent moisture-induced package delamination. However, there are a number of factors that you should consider.
- Exposure to 125 deg. C for 48-hours is conducive to generation of oxides and Intermetallics at the soldered leads. In my opinion, "no-Pb" solders have enough solderability issues without further burdening them with post-baking issues.
- There are likely components like connectors mounted on the board that can not withstand exposure to 125 deg C.
- The 48-hour J-Std-033B baking schedule severely impacts your production schedule.
However, the specification allows for alternative drying schedules like the "Thermal-WallTM" process that can technically support its effectiveness. This new process recovers greater than or equal to 50% of the surface-mount components "floor-life" with only a 34-hour exposure to a 70 deg C, vacuum-assisted baking cycle. The recovered "floor-life" should be sufficient to safely perform any rework procedures.
Pardon any commercialism in our response, but these are the facts that were asked for.
Charles S. Leech Jr., Director of Engineering
Innovative Drying Co.
sleech@qwest.net
Mr. Leech lead a successful two-year long process development effort that identified the parameters required to rapidly dry moisture sensitive devices while they were encased in the tape and reel format. He is the named inventor in two U.S. Patents that address the process of drying. Mr. Leech has over thirty years of experience as a manufacturing engineering manager in the electronics industry.
March 18, 2008
I suggest you refer to IPC/JEDEC J-STD-033B.1.
Table 4-1 of this industry standard provides reference conditions for drying moisture sensitive devices (MSDs) that have exceeded their allowable exposure time. This table is applicable to both unmounted and mounted MSDs.
A bake temp of 90C is usually recommended for drying the MSDs already mounted on a PCBA, prior to rework. The higher bake temp of 125C is NOT generally recommended for PCB Assemblies, because the plastic shrouds on common headers & connectors (which may have been added post-reflow), cannot withstand long-term exposure to 125C.
The required bake duration at 90C ranges from 11 hours to 10 days, depending on the following 3 variables:
1) Moisture Sensitivity Level (MSL) of the MSD(s) on the board.
2) MSD Package Body Thickness
3) Elapsed time since expiration of Floor Life of MSDs on the PCBA. If this is unknown, then the safe bet is to use the column entitled "Exceeding Floor Life > 72 hours".
Based on the above 3 variables, Table 4-1 provides all the information your readers need to ensure MSDs on PCB Assemblies can be sufficiently dried, to survive thermal excursions during rework and repair operations.
Mitch DeCaire, Sales Manager (Americas)
Cogiscan, Inc.
mdecaire@cogiscan.com
Mitch DeCaire, Sales Manager at Cogiscan, has served the electronics manufacturing industry since 1989. His prior experiences include process engineering, business development, and engineering management roles with Nortel Networks, Vansco Electronics, Universal Instruments and Siemens.
March 17, 2008
Depending on the material of the PCB and the thickness, I would recommend a bake time on no more than 10 to 15 minutes.
Gregory Arslanian, Global Segment Manager, Electronics Packaging, Assembly and Test
Air Products and Chemicals, Inc.
arslangk@airproducts.com
Mr. Arslanian has been involved in electronics packaging processing and equipment since 1981 including flipchip, TAB, wirebonding and die attach. He worked in the 3D molded interconnect industry prior to joining Air Products commercial technology and applications team. Current responsiblities include R&D, applications, marketing and customer interaction. Main focus is in inert atmosphere processing and fluxless soldering.
March 17, 2008
I would suggest you check the PCB bill of materials and base your bake time and temperature on the MOST moisture sensitive component on the board. If this information is not available you could bake the assembly for 24 hours.
