March 11, 2008
Precise & Powerful: the PreFeeder 60
The PreFeeder 60 is a high speed prefeeding unit for use with automatic Cut Strip Terminate (CST) machines. A controlled roller drive feeds the wire into an accumulator to reduce tension on the wire before it is pulled by the high-speed feeding mechanism of the CST machine for further processing. The PreFeeder 60 is an excellent solution to maximize productivity of the processing machine, especially when it comes to wire packaging that might be problematic (e.g. wire barrels, loose wires, cardboard boxes). With a maximum feeding speed of 59.5 ft/s (9 m/s) (depending on wire type and wire bundle), the PreFeeder 60 has been optimized for high-speed fully automatic crimping machines such as the Schleuniger CrimpCenter models.
The main features of the PreFeeder 60 are an optimized wire feeding system with a dynamic accumulator to reduce tension on the wire and a controlled roller drive for high feeding speeds. Wire line height can be easily adjusted, and a wire end detection sensor is also available as an option.
The PreFeeder 60 fully complies with all CE and EMC guidelines relative to mechanical and electrical safety and electromagnetic compatibility.
Schleuniger
Cheryl Duszak
http://www.schleuniger-na.com
This page has been viewed 128 times. |
More from Schleuniger
Reed Exhibitions
ZESTRON America
DYMAX Corporation
Krayden
Fine Line Stencil
AVX Corporation
Littelfuse
CheckSum
Orbotech Ltd.
Essemtec
In a move that will help PCB designers work with greater accuracy and efficiency, IPC — Association Connecting Electronics Industries® has ...
IPC
CheckSum
Federal Electronics
Crystek Corporation
SchmartBoard
KIC
IPC
Vitronics Soltec
SMTA
Manncorp
National Electronics Week
Totech Super Dry
PULS Inrush current limiting
PULS
Humiseal
To find more articles from Schleuniger, use the search form below.
