January 21, 2008
Flux Deposition
My production line is running boards with Package-On-Package components.
Our biggest issue is joints that do not solder. Is this due to insufficient flux being applied when we dip the package?
Is there an off line inspection process or machine that can inspect flux deposition on the package contact points before mounting and reflowing the package?
R. A.
This "Ask the Experts" page has been viewed 585 times.
January 24, 2008
The cause is most probably the lack of flux, provided all the reflow parameters are as per specifications. It is assumed that proper reflow temperatures and TAL are achieved. One company that I know of which makes non-contact film thickness measurement system is Lumetrics. The equipment from this company can also measure multiple layers.
Bjorn Dahle, President
KIC
bdahle@kicmail.com
January 21, 2008
The easiest system to use for flux inspection is the VPI-1000 manufactured by Easy Braid Inc. It features up to 400X magnification, on screen measurement and a user configurable defect library.
January 21, 2008
It might be flux, but much more likely you are not reaching reflow temperature due to the mass involved. Run a test with a thermocouple attached to the joint and verify your process.
Bob Black, President and CEO
Juki Corporation
rjblack@jas-smt.com
Mr. Black was the President and Co-Founder of Zevatech in 1977 and introduced first Pick and Place System at Nepcon West 1980. Bob is now the President, CEO and Co-Founder of Juki Automation Systems, formed in 1999. Mr. Blkack is also a Co-Founder of the SMEMA Council of IPC. He serves as a member of SMTA and SEMI.
January 21, 2008
It is highly unlikely that a dipping process is NOT providing adequate Flux. Depending on the nature of the joint failure it may be a lack of heat transfer, poor paste, contact surface finish or flux activity. All could be playing a part.
Allen W. Duck, CEO
ATEK llc
allen@atekllc.com
January 21, 2008
It’s hard to say for sure without seeing the location of the non-soldered joints and analyzing some of their characteristics but Amkor has done much work on POP and has published several papers on the subject.
Check out all of their white papers.
In particular, this white paper talks about the effect of die warpage and the use of a “dipping paste” to bridge the gap and overcome coplanarity issues. This dipping paste gives greater transcription vs. flux and can expand the tolerance band of the process.
Additionally, Amkor has done work on SOP (Solder on Pad) where the top pads on the lower package are bumped and also help to eliminate open joints.
I am truly NOT the expert on this but have spoken with Moody Dreiza once or twice and he is great. Suggest a call or mail to him for more help if needed.
Marc Peo, President
Heller Industries Inc.
mpeo@hellerindustries.com
Mr. Peo has been with Heller Industries for over 20 years and has been President for the past 8 years. Marc has authored several industry articles on Soldering, Flux collection, nitrogen use and Lead Free conversion and has served on the SMEMA Dual Rail committee, the APIA Consortium, the JARA Association and SMEMA Steering Committee.
