Corporate News Index
January 18, 2008
Sunstone Circuits Releases DFM Add-on for Cadsoft Eagle PCB Layout Tool
EAGLE Users Can Design Direct to Sunstone’s Fab
Mulino, Ore.Sunstone Circuits, the Mulino, Ore.-based printed circuit board (PCB) prototype solutions provider, has released a factory certified add-on that enforces Sunstone’s manufacturing capabilities interactively inside CadSoft’s EAGLE PCB Layout™ tool.
“With the DFM Add-On, EAGLE PCB Layout users can now design with more confidence that their PCB will be manufacturable by Sunstone,” said Terry Heilman, CEO of Sunstone Circuits. “By leveraging the Design Rule Checking (DRC) engine built in to EAGLE and supplying a full complement of Sunstone-specific rules for the EAGLE DRC engine, Sunstone ensures that a designer’s work will conform to our published manufacturing capabilities. We will offer this add-on to EAGLE PCB users as a complimentary service, just another way that Sunstone strives to be the easiest and best PCB solutions provider to do business with, Q2D™: from Quote to Delivery.”
Benefits to users of the DFM Add-On include:
  • Reduced costs - helps eliminate design errors early in the design process, minimizing the need for costly corrections later.
  • Reduced time - design a PCB more quickly by utilizing an existing rule deck instead of users creating their own.
  • Process simplification – relieve pain points in the design process by following a rule deck every step of the way.
Ed Robledo, General Manager for CadSoft USA, EAGLE PCB layout’s US distributor, endorses the DFM Add-On, saying “CadSoft’s DRC engine is the ideal place for industry-leading PCB manufacturing firms to characterize their DFM rules. By making a certified correct version of their manufacturing parameters available to our customers, Sunstone is bringing a uniform DRC environment to all EAGLE users.”
“With the DFM Add-On, our EAGLE customers can verify that their design is in compliance with our DFM guidelines at every step of the design process,” added Nancy Viter, Sunstone Customer Satisfaction Manager. “The Add-On helps solve the historical issue of end users having to write their own interpretation of the fabrication vendor’s rules, a process that often leads to errors that are not discovered until late in the design process, thus making them expensive problems to fix.”
Sunstone’s DFM Add-On for EAGLE PCB Layout can be downloaded from Sunstone’s website at http://www.sunstone.com/pcb-resources/Downloads.aspx, or from the CadSoft USA website at http://www.cadsoft.de/download.htm, in the miscellaneous downloads section.
Best-in-Class Design Options for All PCB Designers
As a part of the Sunstone ECOsystem, DFM Add-Ons help bring a seamless design flow to design and assembly services. The Sunstone ECOsystem represents a strategic resource that will consolidate and improve the PCB prototyping process for designers from concept-to-delivery. The Sunstone ECOsystem integrates the four discrete segments of PCB prototyping:
  • Knowledge – PCB designer expertise
  • Tools – design packages and software
  • Libraries and Parts – Sourcing and tracking of PCB components
  • Manufacturing – PCB manufacturing capability and expertise
With DFM Add-Ons and the Sunstone ECOsystem, designers can produce working prototypes in shorter times, fewer turns and with greater access to PCB manufacturing services such as assembly and stenciling. Designers benefit with lower costs and fewer pain points throughout the entire design and manufacture process.
Sunstone Circuits
This page has been viewed 2598 times.
More from Sunstone Circuits
September 2, 2010 - Corporate News
Enthone Introduces ENTEK® OM
Enthone Inc. has introduced ENTEK® OM. The patented, Organic Metal® process delivers a visible, highly conductive PWB final finish that ...
Enthone Inc.
Juki Donates a KE-760 Flexible Placement System to 'Industrial Strength' Equipment Charity Auction
Juki
DYMAX President Appointed to Manufacturing Council
DYMAX
BTU to Highlight Next Gen Thermal Processing Capabilities at EUPVSEC
BTU International
Electrolube Introduces its New Reflow Oven Cleaner at ATE Chicago
Electrolube
ASSET enhances boundary-scan test capabilities on ScanWorks platform for embedded instruments
ASSET® InterTech
NEPCON South China 2010 Kicks Off With Strong Start
Reed Exhibitions
iNETest Technologies India to Showcase BPM Microsystems’ Universal Device Programmer at Electronica/Productronica India
BPM Microsystems
September 1, 2010 - Corporate News
DYMAX Conformal Coating 9481 Mitigates Tin Whisker Formation
DYMAX Dual-Cure 9481 cures in seconds to protect delicate circuitry on tin solder joints. Conformal coatings are recommended for retarding ...
DYMAX Corporation
Manncorp Revamps Entire Line of Rework Systems
Manncorp
Ellsworth Adhesives Launches New Website in Finland
Ellsworth Adhesives
For the Cleanest Boards in the Midwest, Come See Kyzen's AQUANOX® A4703 at IPC Electronics Midwest
Kyzen Corporation
Juki to Debut Innovative Assembly Systems at IPC Electronics Midwest
Juki Corporation
Seika Releases Latest Features for McDry Electronic Drying Storage Cases
Seika Machinery, Inc.
Virtual Ind. to Showcase Vacuum Handling Solutions at IPC Electronics Midwest
Virtual Industries Inc. announces that it will showcase several advanced vacuum tweezer systems in booth 1045 at the upcoming IPC Electronics ...
IPC Conference in Budapest Offers Critical Info on Quality, Reliability
Eastern Europe's growing electronics assembly industry faces new challenges, especially with the adoption of lead-free technology. To ...
IPC
Everett Charles Techs' Contact Products Group Appoints Global Sales Director
Everett Charles Technologies' Contact Products Group (CPG) is announces the creation of a new Global Sales Director position and has selected ...
DfR Solutions Announces Austin Design for Excellence (DfX) Seminar
August 31, 2010 - Corporate News
Aqueous Technologies to Feature Cleaning Equipment at IPC Electronics Midwest
Microscreen Adds Second Exposure Room for Thick Film Screens
Microscreen
ICON Technologies Celebrates 5-Year Anniversary
ICON Technologies announces its five-year anniversary. With its' indirect sales channels, ICON offers an extremely cost-effective and proven ...
ICON Technologies
Bare Board Group Receives 4th Consecutive Placement on the Inc 5000 List
Bare Board Group
BPM Microsystems Introduces 8th Generation Universal Programming System
BPM Microsystems
RMD Instruments to Discuss How to Improve Supply Chain Reliability with XRF Technology at PCB West
RMD Instruments Corp.
P. D. Circuits' Mike Tucker to Present at PCB West 2010
P. D. Circuits, Inc. announces that Mike Tucker, Technical Service Engineer, will hold a presentation titled “A Look At CAM Departments ...
To find more articles from Sunstone Circuits, use the search form below.
