November 8, 2007
atg/LM to Launch A5-A Probe System With Automation at Productronica
atg Luther & Maelzer GmbH announces it will launch the new A5-A Probe System with Automation in Stand 341, Hall B4 at Productronica 2007. The Productronica exhibition and conference is scheduled to take place November 13-16, 2007 at the Munich Trade Fair Center in Munich, Germany.
The A5-A Probe System has been developed in direct response to market needs for a fully functional and affordable automated test platform for the small manufacturing facility. Taking proven atg/LM technology, the A5-A Probe System has been fully automated to meet the needs of companies with as little as one production line.
Small manufacturing facilities typically produce low volume batches or prototypes, which results in a high level of product changeover. To eliminate the need for long and complicated setup and adjustment of each PCB, the A5-A Probe System incorporates a new generation of automation to accommodate different PCB types and sizes within a short period of time. To speed this process a flexible, stress free loading and uploading system has been fully automated, with a sensitive handling function, for different PCB types. By automating this function the operator is free to perform other duties during their shift, or to set up the test process to be carried out overnight, simulating a third shift. Incorporating four high resolution CCD cameras for optical scanning, the board handling unit automatically separates ‘good boards’ and ‘bad boards’ in a cycle time of less than fifteen seconds, with the added option of an automated marking system.
The A5-A Probe System can accommodate a minimum 100 mm x 72 mm (4.0“ x 2.8“) and maximum 610 mm x 460 mm (24“x18“) board size. The minimum thickness is 0.8 mm down to a board size of 320 mm x 250 mm (12“ x 10“) and 0.6 mm lower than 320 mm x 250 mm (12“ x 10“), with a maximum of 4mm (0.15“). atg/LM’s new A5-A Probe System ensures that even small manufacturing facilities can rely on the quality and reliability of the products tested, making automated test affordable for all.
Peter Brandt
http://www.atg-test-systems.de
This page has been viewed 201 times. |
More from atg Luther & Maelzer GmbH
ZESTRON America
DYMAX Corporation
Fine Line Stencil
Reed Exhibitions
AVX Corporation
Littelfuse
Krayden
CheckSum
Orbotech Ltd.
Essemtec
In a move that will help PCB designers work with greater accuracy and efficiency, IPC — Association Connecting Electronics Industries® has ...
IPC
CheckSum
Federal Electronics
Crystek Corporation
SchmartBoard
KIC
IPC
Vitronics Soltec
SMTA
Manncorp
National Electronics Week
Totech Super Dry
PULS Inrush current limiting
PULS
Humiseal
To find more articles from atg Luther & Maelzer GmbH, use the search form below.
