October 31, 2007
Aqueous to Premier the Trident Automatic Defluxing System at Productronica
RANCHO CUCAMONGA, CA — Aqueous Technologies Corp. announces that it will introduce the Trident, its fourth-generation automatic defluxing system, in Area A4, Booth 434 at the upcoming Productronica 2007 exhibition and conference scheduled to take place November 13-16, 2007 at the New Munich Trade Fair Center in Munich, Germany. The Trident Series represents the next generation of lead-free compatible, fully automatic post-reflow defluxing systems.
http://www.aqueoustech.com
This page has been viewed 192 times. |
More from Aqueous Technologies
January 6, 2009 - Corporate News
IPC Issues Updated PCB Production and Laminate Market Report
IPC recently issued its World PCB Production and Laminate Report for the Year 2007. Based on the best data available, the report presents ...
IPC
Large-Sized LCD Panel Shipments Decline in Q4
Following a 3% sequential decline in the third quarter, global unit shipments of large-sized LCD panels decreased by another 5% in the ...
iSuppli Corporation
Agilent Pledges to Reduce Greenhouse Gas Emissions
Agilent Technologies Inc. has announced its participation in the U.S. Environmental Protection Agency's (EPA) Climate Leaders program ...
STI Electronics Inc. Appoints Clifton J. Powell as Outside Sales Representative
STI Electronics, Inc.
Matrix Circuits LLC, a fresh new face on the EMS scene
Matrix Circuits LLC
Ken Morton Joins Tridak as Dispense Systems Engineer
Tridak
January 5, 2009 - Corporate News
STI Electronics Names Lee Pulliam as Outside Sales Rep.
STI Electronics Inc
Crystek Microwave Introduces New CPPD Line Of Frequency Multipliers
Crystek Microwave
December 31, 2008 - Corporate News
WKK Signs License Agreement with Nihon Superior
WKK Technology Ltd.
Second-Generation PlayStation 3 Features Cost Reduction, Supplier Shifts
Sony Corp.'s new-generation PlayStation 3 (PS3) features a cost-reduced design due to integration and some key changes in components from the ...
iSuppli Corporation
DfR Solutions Invited to Participate in the GEIA APMC Meeting
December 30, 2008 - Corporate News
Solar Market Eclipse Coming in 2009, iSuppli Warns
Bringing an end to eight consecutive years of growth, global revenue for Photovoltaic (PV), panels is expected to plunge by nearly 20 percent ...
iSuppli Corporation
CCID Consulting: Review and Forecast on China's Electronic Information Industry
CCID Consulting, China's leading research, consulting and IT outsourcing service provider, and the first Chinese consulting firm listed in ...
CCID Consulting
December 29, 2008 - Corporate News
Notebook PC Shipments Exceed Desktops for First Time in Q3
Global notebook PC shipments exceeded those of desktops on a quarterly basis for the first time ever in the third quarter, marking a watershed ...
iSuppli Corporation
LaBarge, Inc. Acquires Pensar Electronic Solutions LLC
LaBarge, Inc.
December 24, 2008 - Corporate News
STI Moves into New Upgraded Facility
Saratoga County CEOs Ranked Among The 'Best CEOs' In Nation
Sono-Tek Corporation
Inovar Expands Capabilities with New X-Ray Fluorescence System
Inovar
EI Expands with UK Office and Appoints European Sales Director
Endicott Interconnect Technologies, Inc. (EI) announced it has created EI Technologies UK Limited, a wholly owned subsidiary of EI and located ...
December 23, 2008 - Corporate News
IPC Market Research Library Available At No Charge to Members
IPC
MYDATA announces MYTRACE - secure traceability software
MYDATA
PROMATION Appoints New Marketing Manager
PROMATION, Inc.
Intertronics Have The Answers!
Intertronics
Crystek Microwave Introduces CPPD Line Of Frequency Multipliers
Crystek Corporation
December 22, 2008 - Corporate News
SMTA Announces AIMS Harsh Environment Electronics Symposium Call For Papers
SMTA
To find more articles from Aqueous Technologies, use the search form below.
