RANCHO CUCAMONGA, CA — Aqueous Technologies Corp. announces that it will premier the Trident, its fourth-generation automatic defluxing system, in booth 1019 at the upcoming Assembly New England/Nepcon East exhibition and conference scheduled to take place October 30-31, 2007 at the Boston Convention & Exhibit Center. The Trident Series represents the next generation of lead-free compatible, fully automatic post-reflow defluxing systems.
