September 4, 2007
Control Electronic Static Discharge
How can I control Electronic Static Discharge in my automated handling equipment?
S. D.
This "Ask the Experts" page has been viewed 588 times.
September 4, 2007
All equipment should be grounded through the power cord.
If any portion of the equipment is isolated from the chassis ground then electrical connections should between all the pieces or sections of the equipment so it is all grounded. It can be as simple as having a conductive floor and using chains to drag onto the floor, or using metal pads for the feet of the equipment on the grounded floor.
One should also review the equipment for any element which may not be static dissipative allowing an electrical charge to build up, for example a place where paper is slid across a non metallic surface or a conveyor that is supported by non metallic supports or isolated from the base system. When these conditions are evident, wires can be installed to ground the units together.
leo@eptac.com
September 4, 2007
Inside of the AHE (automated handling equipment) you have ESD events, called from CDM (Charged Device Model). This ESD event is very fast. For ESD control you shell first all metal parts are grounding and second you shell use an ionizer. The ionizer shell is placed inside of the AHE. The ionizer shell discharge the electronic device and the PCB directly before the electronic device placed on the PCB.
If you have more questions, we have a very long experience in static control, also inside of machines or outside on workstation.
Hartmut Berndt, President
B.E.STAT group
hberndt@bestat-esd.com
I've been in Electronics & Semiconductor Technology since 1980 and work in the area of Electrostatic (ESD) and electronic devices. Since 1995 I’ve been an expert in the standard committees and since 2002 secretary of TC 101 at IEC Electrostatics, President of the B.E.STAT group (Germany); expert for ESD audits, trainings, failure analysis and for ESD control programs.
September 4, 2007
In most cases, electrostatic discharge protection should be built into the equipment, it is difficult to retrofit, but I can give you some tips.
- Talk to the equipment supplier. They should know how to control ESD on their equipment.
- One of the most common sources of static charge is on the conveyor. See if the equipment supplier has some ESD belts or conveying chains and make sure the conveyor is grounded.
- Get a digital static meter. You can find one on-line by Googling “static meter”. Use the static meter to find areas where there is high charge and ground that area.
- Ion fans are available. Again, Google is your friend. I tried “static discharge ion fan” and several came up. They help dissipate static charge, particularly in dry environments. They can help, but won’t prevent a serious problem.
- If you are in a very dry environment, consider small increases in humidity.
- Look for areas where plastic or rubber is used to isolate metal parts, particularly those that have some electrical component on them. Create a ground path for these areas.
Alan Lewis, Director of Application Engineering
Asymtek
alewis@asymtek.com
Mr. Lewis worked for The Aerospace Corporation for 6 years before joining Asymtek in 1993. He holds multiple patents in dispenseing technology for electronics assembly and packaging. He has a Master's Degree in Mechnical Engineering from University of Missouri-Rolla.
September 4, 2007
Contact the manufacturer of the equipment for this information
Bob Black, President and CEO
Juki Corporation
rjblack@jas-smt.com
Mr. Black was the President and Co-Founder of Zevatech in 1977 and introduced first Pick and Place System at Nepcon West 1980. Bob is now the President, CEO and Co-Founder of Juki Automation Systems, formed in 1999. Mr. Blkack is also a Co-Founder of the SMEMA Council of IPC. He serves as a member of SMTA and SEMI.
