Ask the Experts Panel Submit A Question  |   Index
Edward Zamborsky No. 40986
Edward Zamborsky Regional Sales Manager
Mr. Zamborsky serves as one of OK's technology advisors to the Product Development group. Ed has authored articles and papers on topics such as; Low Volume SMT Assembly, Solder Fume Extraction, SMT Rework, BGA Rework, Lead Free Hand Soldering, Lead Free Visual Inspection and Lead Free Array Rework.
Experts Questions Answered by Edward Zamborsky
Aug 30, 2010 SMT Components Popping Off During Reflow
Jul 6, 2010 Options for Reducing Dross
Jun 28, 2010 Through Hole Component Phase Out
Jun 1, 2010 What Causes Chip Component Blow Out
Jun 1, 2010 What is the Shelf Life for a Syringe of Solder Paste
May 24, 2010 Humidity Inside Our Screen Printer
May 24, 2010 Lead-Free Profile on Tin/Lead Assemblies
May 17, 2010 BGA Rework Flux Recommendation
Apr 5, 2010 Lead-free Assemblies Reworked with Leaded Solder
Mar 8, 2010 Contamination Prior to Conformal Coating
Mar 1, 2010 Is Baking Required After Aqueous Cleaning?
Feb 22, 2010 Most Difficult Components to Hand Solder
Feb 1, 2010 BGA Shifting During Reflow
Dec 14, 2009 Tombstoning Dilemma
Dec 7, 2009 SN96 Solderability Issues
Dec 7, 2009 SMT Component Lead Oxidation
Nov 23, 2009 Concerns Using Hand Sanitizers
Nov 2, 2009 Hand Soldering Alternative
Oct 26, 2009 Tacky Flux Residue Problem
Oct 19, 2009 Issues with BGA Components Near PCB Edges
Sep 28, 2009 Solder Joint Explosions
Sep 21, 2009 Components Lifting During Wave Soldering
Sep 14, 2009 Hard Water Contamination
Sep 14, 2009 Solder Joint Rework Question
Aug 31, 2009 Mysterious Solder Balls
Aug 31, 2009 Small chip cap rework advise
Aug 10, 2009 Reworked BGA component bridging at the corners
Aug 5, 2009 SMT Component Shift
Jul 27, 2009 Estimated SMT component placement cost
Jun 29, 2009 How to Clamp Odd Shaped Circuit Boards
Jun 1, 2009 Technology to Measure Oxidation Levels
Jun 1, 2009 Blow Holes on Clinched Radial Lead Components
May 26, 2009 Which term to use, PWB or PCB?
Mar 2, 2009 Measuring component height after reflow
Mar 2, 2009 Ideal humidity for circuit board assembly
Feb 2, 2009 Conformal Coating & Humidity
Jan 26, 2009 BGA Replacement limit
Jan 26, 2009 Wave solder process issue
Dec 14, 2008 Micro-balling with lead-free HASL and SAC alloy
Dec 8, 2008 Double Sided Reflow
Nov 24, 2008 Solder Bump QFN's
Nov 10, 2008 Opens on BGA solder joints after reflow soldering
Oct 13, 2008 Solder to a thin flexible circuit
Sep 8, 2008 Rework Circuits Under BGA's
Sep 2, 2008 Lead Free Flux
Aug 18, 2008 Voids in leadless packages
Aug 11, 2008 Through Hole Soldering on 24 Layer Board
Aug 4, 2008 Reflow BGA's with CSP's
Aug 4, 2008 Recover Solder from Dross
Jul 21, 2008 BGA Rework
Jun 30, 2008 Multiple Lead-free Profile
Jun 23, 2008 What is Jell Flux?
Jun 16, 2008 Solder Components to Thin Flexible Circuits
Jun 2, 2008 Leaded Solder on ROHS Compliant Parts
May 12, 2008 How many zones are adequate for lead free profile
May 12, 2008 Solder bridging on BGA's
Apr 28, 2008 Reduce voids in QFN pb-free reflow process
Apr 28, 2008 Carbon Dioxide generated and trapped by conformal coating
Apr 21, 2008 Eutectic reflow for Pb-free BGAs
Mar 17, 2008 Bake for Repair
Feb 4, 2008 Lead Float
Jan 21, 2008 Flux Deposition
Jan 21, 2008 BGA bridging defects
Dec 10, 2007 Pre clean boards before printing
Dec 3, 2007 Part Movement During Reflow
Nov 12, 2007 Rework Metal BGA's
Nov 5, 2007 Voids in BGA's
Oct 29, 2007 Component Shift During Reflow
Oct 29, 2007 Wave soldering LCDs
Oct 8, 2007 Keep package in place during reflow
Oct 1, 2007 Clean before wave soldering
Sep 23, 2007 Coating or encapsulating tin-lead solder joints?
Sep 23, 2007 Solder Paste Hang up
Sep 17, 2007 BGA Rework - with or without solder paste
Sep 17, 2007 Voids in Solder Balls
Jul 30, 2007 Wire stripping insulation prior to tinning
Jul 2, 2007 BGA re-balling process
Jun 18, 2007 Tombstone problems
Jun 11, 2007 Hand soldering process
Jun 4, 2007 Stencil printing process problems
May 14, 2007 RFID Technology for Pick and Place feeders
Apr 10, 2007 Should we buy new low cost assembly equipment
Apr 10, 2007 Plating thickness for lead-free HASL
Apr 2, 2007 Lead-free connector rework
Mar 4, 2007 Books or Publications of today's electronics assembly
Feb 19, 2007 Wave solder and reflow 0805 capacitors and resistors
Jan 29, 2007 Temperature Time Transformation
Jan 29, 2007 Lead-free soldering problem
Jan 22, 2007 Double sided SMT
Jan 22, 2007 Cleaning PCB Boards with window cleaner?
Jan 22, 2007 Small component rework
Dec 27, 2006 Hand soldering skills
Nov 5, 2006 Tombstone problems
Oct 2, 2006 Proper hand soldering settings
Sep 18, 2006 Hand soldering for Lead-Free
Aug 14, 2006 Coating to stop tin whisker growth?
Jul 31, 2006 Hand-held XRF system question
Jun 29, 2006 Regarding lead free, can I use the reflow ovens I currently have in production?
Jun 29, 2006 What should the average temperature and humidity level be in an electronic assembly facility?
