Dr. Brian Toleno |
Member No. 40979 |
Application Engineering
Henkel Technologies
brian.toleno@us.henkel.com
Dr. Brian Toleno is the Application Engineering Team leader for Henkel Technologies. He is responsible for the technical service and application engineering for Henkel's electronics assembly materials, including solder paste, underfills, PCB protection materials, and underfills. He holds a Ph.D. in Analytical Chemistry from The Pennsylvania State University and a B.S. degree in Chemistry from Ursinus College.
Experts Questions Answered by Dr. Brian Toleno
Oct 27, 2008 |
Adhesive for sensor attachment
Oct 6, 2008 |
Oxidation on pads causes poor solder joints
Oct 6, 2008 |
IR Reflow Issue
May 5, 2008 |
Reduce voids in QFN pb-free reflow process
Sep 9, 2007 |
Reflow for leaded and lead-free assemblies
Aug 20, 2007 |
Good epoxy or cement for bonding BGA packages to PCB
Jul 16, 2007 |
SMT adhesive problems after wave solder process
Feb 4, 2007 |
Baking lead-free and lead PCB’s before assembly
Feb 4, 2007 |
Reflow parameters for lead-free BGA
Dec 4, 2006 |
Oxidation on plated through holes
Nov 20, 2006 |
Proper method to bake PCB's
Oct 30, 2006 |
Tin lead soldering of lead free components
Oct 30, 2006 |
Cleaning an assembled board with IPA
Oct 23, 2006 |
Wave Soldering creating blowhole problems
Sep 5, 2006 |
Lead free BGA's and HASL
Sep 5, 2006 |
Help debugging wetting problems
Aug 16, 2006 |
Coating to stop tin whisker growth?
Aug 7, 2006 |
Studies showing the effects of PCB finish on manufacturability
May 18, 2006 |
Is it possible to run Pb-Free reflow without nitrogen?
May 3, 2006 |
RoHS existing products vs. new products
Apr 23, 2006 |
Can PCB's designed for Sn/Pb be used in a Pb free assembly?
Apr 13, 2006 |
Advise and suggestions for assembly using 01005 capacitors.
Apr 5, 2006 |
Lead-free solder pastes drop-in replacements?
Apr 3, 2006 |
BGA rework pre-bake. Yes or no?
