Leo Lambert |
No. 40948 |
leo@eptac.com
Experts Questions Answered by Leo Lambert
Jun 28, 2010 |
Through Hole Component Phase Out
May 17, 2010 |
Rules for Reusing Components
May 10, 2010 |
Can Water be Harmful to Electronics Components?
May 10, 2010 |
Lifted Leads on QFP
May 5, 2010 |
Solder Fillet Peaks
May 3, 2010 |
Recommendation for PCB Surface Finish
Apr 19, 2010 |
PCB Handling and Storage Concerns
Mar 29, 2010 |
Cleaning No-Clean Solder Paste
Mar 1, 2010 |
Is Baking Required After Aqueous Cleaning?
Feb 15, 2010 |
Which to Use - Rosin Flux or Water Soluble?
Oct 26, 2009 |
Class 2 vs. Class 3 Distinction
Aug 5, 2009 |
SMT Component Shift
May 26, 2009 |
Which term to use, PWB or PCB?
May 18, 2009 |
Recommended lead to hole ratio
Mar 30, 2009 |
Alternative to Conformal Coating
Mar 30, 2009 |
Screen Print Shelf Life
Feb 23, 2009 |
Re-certify a reflow oven
Jan 26, 2009 |
Wave solder process issue
Oct 20, 2008 |
Cleaning No-clean Flux
Oct 20, 2008 |
Tin-lead and no-lead compatibility issues
Sep 8, 2008 |
Rework Circuits Under BGA's
Sep 8, 2008 |
Halogen Free tin lead or pb free
Aug 18, 2008 |
What is the correct coupon for moister and insulation test
Aug 11, 2008 |
Wave Soldering Problems
Aug 11, 2008 |
Through Hole Soldering on 24 Layer Board
Aug 4, 2008 |
Recover Solder from Dross
Aug 4, 2008 |
Reflow BGA's with CSP's
Jul 6, 2008 |
Humidity and Corrosion
Jul 1, 2008 |
Best Board Cleaning Methodology
Jun 16, 2008 |
Urethane Conformal Coating Problem
Jun 16, 2008 |
Solder Components to Thin Flexible Circuits
Jun 9, 2008 |
Solder Deposits on Components During Wave Soldering
May 27, 2008 |
No-Clean Flux: How much is too much?
May 12, 2008 |
Solder bridging on BGA's
May 12, 2008 |
How many zones are adequate for lead free profile
Feb 25, 2008 |
Acceptable Number of Repairs
Feb 25, 2008 |
How much Board Baking is to much?
Feb 4, 2008 |
Lead Float
Jan 14, 2008 |
Solder Paste Replenishment
Jan 2, 2008 |
Zinc in solder
Dec 3, 2007 |
Part Movement During Reflow
Nov 19, 2007 |
Maximum thermal stress temperatures
Nov 19, 2007 |
Pros and cons of HASL, OSP and Immersion Gold
Oct 29, 2007 |
Wave soldering LCDs
Oct 29, 2007 |
Component Shift During Reflow
Sep 23, 2007 |
Coating or encapsulating tin-lead solder joints?
Sep 4, 2007 |
Deflux Eutectic and Lead-Free Assemblies
Sep 4, 2007 |
Control Electronic Static Discharge
Aug 27, 2007 |
Conformal Coating Specification Violation
Jul 30, 2007 |
Scribe lines for depaneling boards
Jul 30, 2007 |
Wire stripping insulation prior to tinning
Jul 30, 2007 |
SMT Epoxy for lead-free wave
Jul 2, 2007 |
Any "Standards" on pad repairs?
Jun 25, 2007 |
Monitoring temperature and humidity
Jun 25, 2007 |
Lead Free BGA Reflow
Jun 11, 2007 |
Using tin-lead solder on RoHS parts
Apr 15, 2007 |
HASL and solder mask process?
Apr 15, 2007 |
Jumper wire guidelines
Apr 2, 2007 |
Cleaning tin-lead and lead-free boards
Mar 4, 2007 |
Lead-free bar solder for wave soldering
Mar 4, 2007 |
Books or Publications of today's electronics assembly
Mar 4, 2007 |
Cleaning solvent to replace Forane 141b?
Jan 22, 2007 |
Small component rework to IPC spec.
Jan 22, 2007 |
Cleaning PCB Boards with window cleaner?
Jan 22, 2007 |
Double sided SMT
Dec 27, 2006 |
Hand soldering skills
Dec 18, 2006 |
OSP Board rework and cleaning
Dec 11, 2006 |
Reflow and wave soldering OSP Boards
