Pb-free voiding: What’s on the surface?
PCB surface finish may have more of an impact on lead-free solder joint voiding than you think. Read the latest research on the topic and learn which surface finishes yield the best results... Henkel Complete the form below. After you hit submit you will be redirected to the White Paper page. Please be patient, it may take a few seconds for the White Paper to load. | ||
| This page has been viewed 664 times. |
