August 28, 2006
RoHS tantalum capacitors burning during functional test
We manufacturing RoHS boards with SAC305 solder paste for a customer. During the functional test, many tantalum capacitors (RoHS ready) burn and carbonize. Our reflow peak on the capacitor area is 240 deg. C, thermal profile made with KIC navigator, BTU Pyramax. We follow paste and parts temperature specifications.To correct the problem, our customers ask us to manual soldering the tantalum capacitor on the board after the reflow because they associate the problem to the heat of tantalum caps during reflow.
Does somebody see this kind of problem with RoHS tantalum caps? Do the manual soldering with tips at 750 deg C not make sense for me compare to reflow.
Constantin Hudon
VTI
This "Ask the Experts" page has been viewed 1385 times.
August 28, 2006
Yes we have seen this type of issue before.
These are very difficult to assemble in reflow depending on the size and density of the board. One trick you may try is to reduce you top side temperature and increase bottom side heating. This will help keep the capacitor from getting as hot. You may also want to play with your convection air flow on the top side to reduce the heating.
AIM
kseelig@aimsolder.com
August 28, 2006
You may be experiencing popcorning of your tantalum capacitors. We have observed this with several of our clients. Visually inspect and cross-section a random sample of caps post-reflow and see if you observe cracks. If yes, improve your storage conditions and the failures should go away.
chillman@dfrsolutions.com
August 28, 2006
My product is actually for selective soldering and not reflow soldering, but... recently I've been approached because of this same issue you are having. I will be doing a special application using a selective soldering machine to simply touch the bottom side of the board to a mini-wave and use it to reflow the solder on the top side. Of course the board has nothing on the bottom so there is nothing to interfere with it.
I don't know much about your actual process or another solution but I wanted to answer your question "Does somebody else see this problem". The answer is yes, other people see this problem. I hope there will be a better answer for you to correct this. But please contact me if I can help.
Todd O'Neil, Product Mgr, Selective Solder
JUKI Automation Sys.
toneil@jas-smt.com
Todd O'NeilMr. O'Neil has been part of the electronics manufacturing field for nearly 17 years. As Product Manager for Selective Soldering at JUKI, his main objective is to continue the "Lowest Cost of Ownership", and superb reputaion for sales and serivice that JUKI has been so well know for with their Pick and Place equipment.
August 28, 2006
We have seen several situations where capacitors can fail if the internal core temperature of the cap goes above 150 ° - 180 °. The temperature is a function of the part itself and should be verified with the component vendor.
The key is the core temperature. So we recommend drilling a small hole in through the top of the capacitor and inserting a Thermocouple wire down into the core of the cap. Then seal it up with high temperature adhesive /epoxy. In this way you can properly measure the core temperature of the part and develop profiles accordingly.
In general, you can achieve profiles that will satisfy the solder joint temperatures of 235-240 and keep the body cool. In some cases, you may need to utilize differential temperatures between top and bottom heated zones. For example, when reflowing the cap on the top side of the board you can reduce the top side heater zone temperatures and increase the bottom side zone temperatures. The heat will conduct through the board and reflow the joints while the “cooler” air on the top helps to keep the capacitor body within spec.
Your oven supplier can work with you on the details. The best thing to do is provide the oven supplier with the profiles you are running now and the parameters you need to meet and they can typically provide guidance on changes to zone temperature and process.
But it would be best to get that capacitor outfitted with a T/C first and then run it through so the oven vendor can have that baseline info from which to operate.
Marc Peo, President
Heller Industries Inc.
mpeo@hellerindustries.com
Marc PeoMr. Peo has been with Heller Industries for over 20 years and has been President for the past 8 years. Marc has authored several industry articles on Soldering, Flux collection, nitrogen use and Lead Free conversion and has served on the SMEMA Dual Rail committee, the APIA Consortium, the JARA Association and SMEMA Steering Committee.
