October 9, 2006
Aqueous Cleaning Process
Which cleaning solution is preferred for localize cleaning on PCB board before and after the PCB goes through AQUEOUS washing?
1) IPA (isoprophyl alcohol) or
2) DI Water
N.D.
This "Ask the Experts" page has been viewed 1181 times.
October 10, 2006
Neither. IPA is a very poor solubilizing agent. DI-water will only be able to clean inorganic contamination. You best bet is to use a cleaning solution that is able to accomplish both. As a result you can use your aqueous washer as a subsequent rinse.
Umut Tosun, Application Technology Manager
Zestron America
Mr. Tosun has published numerous technical articles in the leading electronic manufacturing magazines. As an active member of the SMTA and IPC organizations, Mr. Tosun has presented a variety of technical papers and studies on topics such as "Lead-Free Cleaning" and "Climatic Reliability".
October 10, 2006
In my experience, NEITHER alcohol nor water do a very good job at localized cleaning on a PCB after the board has been washed in an automatic cleaning system.
Let's assume you have a circuit board that has been assembled, soldered, cleaned and tested, and now needs a bit of rework for some reason.
Water, by itself, does a very good job on the polar contamination but cannot easily dislodge the organic contamination in fluxes. It also is extremely slow drying, which means the technician has to wipe up the water or blow it off the board, extra steps which cost money.
Alcohol, by itself, is a weak cleaner that doesn't remove very much. Most alcohol cleaners saturate (that is, stop cleaning) when carrying only 2-3% contamination. If you use 5 grams of alcohol on a circuit board, it can only carry 0.1 grams of flux residues... a tiny amount, indeed.
I would recommend using a more modern, more sophisticated cleaning answer. Many companies sell such cleaners (including my company, Micro Care) and they are not all fancy and expensive, and some of them deliver great cleaning results at very low cost. For example, one fast-drying product made by my company saturates at 7% by weight, and some get up to 30% or more.
Look also for nonflammable solvents, for fast-drying solvents, and ones that have reduced aroma.
Mike Jones, Vice President
Micro Care
October 9, 2006
We routinely use isopropyl alcohol for simple bench top cleaning during repair and rework. IPC has a somewhat involved procedure following a mil standard. We don't quite follow it to the letter, but you can see our version of this procedure online at: http://www.circuitrework.com/guides/2-2-1.shtml
Jeff Ferry, President
jferry@circuitrework.com
Mr. Ferry is President of Circuit Technology Center, a world-leading contractor for the repair and rework of assembled circuit boards founded in 1983. Jeff also serves as Co-Chairman of the IPC Reparability Committee and as Publisher of Circuitnet and Semiconductor Packaging News.
October 9, 2006
It depends on what types of residues you are trying to remove.
If you are trying to clean rosin-based or other no-clean residues, a localized water clean won't help. IPA would be a better choice, but not necessarily the best choice as there are cleaning chemicals on the market that are designed specifically for rosin-based and other no-clean residues. I would suggest contacting companies like Chemtronics or Techspray for materials that would be better than IPA for this application.
If the residues that are being removed are water soluble, DI water would be the better approach, but I'm not sure why you would need to wash in water prior to an aqueous wash. More details about your process and what you are trying to clean would be necessary to make more specific recommendations.
It would be advised to contact the vendor of the materials that are being removed to get the optimal recommendation.
Kester Paste
bsmith@kester.com
October 9, 2006
First, localized cleaning is actually localized flux dilution. To fully remove flux residues from a localized area, one must clean (wash and rinse) the entire board.
The cleaning media you choose depends on which specific flux you are removing. Water will not work on no-clean or rosin based fluxes. IPA, although capable of removing rosin and no clean flux residues, is not a great solvent and has been banned in many states as a cleaning media.
There are many good cleaning cleaning chemicals designed for thorough flux removal that are effective and environmentally safe. Cleaning eqiupment manufacturers can recommend specific chemicals.
Mike Konrad, President
Aqueous Technologies
konrad@aqueoustech.com
Mr. Konrad has been in the electronic assembly equipment industry since 1985. Michael is founder and CEO of Aqueous Technologies Corporation, a California based manufacturer of automatic de-fluxing equipment, chemicals, and cleanliness testing systems. He is a member of SMTA and IPC. He sits on SMT Magazine's Editorial Advisory Board and is a member of the IPC-APEX Tradeshow Exhibitor's Committee.
October 9, 2006
I don’t like localized cleaning. If there is an intensive need to perform a soldering operation after aqueous cleaning, we recommend using a no-clean no-halide flux with a low solids content.
chillman@dfrsolutions.com
