January 22, 2007
Double sided SMT
Can you provide some process pointers on soldering 2 sided SMT?
Bernie Irving
ARMA Design
This "Ask the Experts" page has been viewed 1405 times.
January 29, 2007
Do not underestimate the importance of proper board support for your double sided application. First and foremost, a robust SMT process requires an accurate print with volumetric repeatability. One critical factor to a quality print is the board support. Without proper support, the board will bow downward during the print stroke increasing the volume of paste transferred, encouraging bridging.
Single side builds are relatively easy to support with simple support pillars which come with most stencil printers today. However, these same pillars are often the root cause of defects for double sided applications.
Components on the bottom side limit the possible support areas available for that board. Even when there are enough open areas available, it isn't always easy for an operator to position the supports in the correct position. And how do you document these positions to eliminate this as a process variable in the future? Support pillars can be used if the component population isn't too dense, but these issues must be addressed in operator training and with setup protocols in place to ensure a repeatable process.
Dedicated tooling, a blank support plate with component locations routed out, provides process repeatability, but will also added cost. However, if the component density is too high, it still may not be possible to provide the support needed. In these cases compliant tooling is a solution.
Compliant tooling modules have support rods with adjustable heights that lock in position once set. This method enables you to support the board even if there is a component present.
For double sided applications, I've found money saved on inexpensive board support solutions is often spent many times over at the rework station.
Michael O'Hanlon, Applications Supervisor
DEK
mohanlon@dek.com
Mr. O'Hanlon currently serves as the DEK Applications Supervisor for the Americas region. He has over 20 years of electronics manufacturing industry experience and has spent the last 13 years at DEK providing equipment utilization and process solutions for SMT manufacturing.
January 22, 2007
The best way to look at double sided SMT assembly is to break it down into 2 single sided SMT assemblies. This is how you will process the board.
Most assemblers will process the higher density side first, since this side requires more heat. Doing it this way, when you reflow the low density side, you have a lower risk of dropping off components due to the thermal requirements of the board.
If you choose to reflow both sides simultaneously, the less complicated side will require the addition of SMT adhesive, this extra step will insure that the components on the bottom stay in place during the heating operation. Keep in mind this will require an extra step, it will be more difficult to reflow and it also makes rework harder due to the stuck on parts.
January 22, 2007
Design the board so that heavy components (power components, large BGAs, etc.) are on one side (the second side).
Make sure you have good support under the board during the second reflow.
Customize the profile for each side (it won’t necessarily be the same).
Depending upon the design, you may need to shield the first side from the peak temperatures during the second reflow.
chillman@dfrsolutions.com
January 22, 2007
Double sided surface mount products have been manufactured for many years and the process is typically the same as it is for products manufactured with components only on one (1) side.
Review the profile to include the extra mass of the components on side 1.
Review the weight of each component that will be on side (1) during the second side reflow as these solder joint will become liquidus and you are expecting the surface tension of the solder to hold these components in place.
Review the thermal profile across the entire board, front – back – sides – top and bottom, the total delta of temperature should not exceed 5 to 10 C.
Make sure your conveyor is keeping the boards up off the belts.
Make sure your boards do not warp or twists as they are being reflowed the second time or for the first time for that matter as this will impact solder joint reliability.
These are just some of the issues needing immediate attention and I would suspect more information will be provided by others on this questions. If more help is needed please get in touch with one of us and we should be able to provide more in depth advise.
leo@eptac.com
January 22, 2007
The number of variables associated with SMT processing of a single-sided board is staggering. Adding a 2nd side makes the situation even more complex!
One key common to all SMT process success is process control. Utilizing test and inspection in the correct balance and configuration to match your line's goals will help achieve process control.
Without more information it is difficult to assess at what points your production line(s) would benefit most from a test and inspection insertion but knowing that you are doing 2 sided or doube-sided boards you will need to consider an inspection technique that enables you to test both sides of the boards simultaneously. Doing this can help identify process defects in a 2 sided configuration which can enable you to identify upstream processes to target and/or variables to focus on.
Stacy Kalisz Johnson, Americas Marketing Development Manager
Agilent Technologies
stacy_johnson@agilent.com
Stacy Kalisz JohnsonMs. Johnson's entry into the electronic packaging arena was as a Package Development Engineer. With a strong process background, Stacy transitioned to the test and measurement equipment world in 2000. Stacy was an Automated Optical Inspection (AOI) and Automated X-ray Inspection (AXI) Product Manager for several years, respectively. Stacy recently joined the Americas Field Marketing Organization as a Marketing Development Manager for the Americas where she continues to work on AOI, AXI and also In-Circuit Test.
