| White Paper Download |
Index |
A 20GHz pluggable 0.5mm pitch BGA connector simplifies test/verification
Today's electronic packages have high clock speeds (multi GHz range), fine pin densities (below 0.4 mm pitch) and high pin counts (over 2000). When these packages assembled onto a printed circuit board (PCB), they perform certain functions at certain speed...
Ironwood Electronics
