Guidelines for Component Placement
Functionality is usually top priority when designing a circuit board. But experienced designers can place components in a way that increases performance AND reduces manufacturing costs. While every board designed is unique, with different requirements, there are basic guidelines of placement that will go a long way toward creating a professional board that can be easily moved from design table to reality. Read this white paper to learn tips and tricks for designing higher quality circuit boards.
Advanced Assembly
