White Paper Submit Form
PCB Troubleshooting - Start with the Connectors
Paper discusses troubleshooting circuit boards by using power-off test instruments to test at the connector level first. Method saves time by testing at PCB points where overvoltage stress and surges first enters the circuit board.
Huntron, Inc.
This page has been viewed 1003 times.
