White Paper Download |
Index |
Spin-Coating Waferbumping Fluxes for Semiconductor Assembly
Wafer bumping flux can turn rough, ugly plated solder bumps into the low-oxide, coplanar bumps needed for a reliable flip-chip joint. This paper details how to achieve uniform thickness of flux with the correct process setup and parameters.
