White Paper Submit Form
How Clean Should An Assembly Be To Be Functionally Good?
Establishing "how clean is clean" is not straightforward. No single answer will suffice; it is finding the ideal balance between the effects of electricity and humidity on a circuit that may be either high or low voltage, high or low frequency, and long or short warranty.
Gen3 Systems
This page has been viewed 1297 times.
