White Paper Download |
Index |
Plasma Clean to reduce Wire Bond Failures
A Plasma process prior to wire bonding will always deliver a cleaner surface to bond to. Potential benefits are improved wire bond statistics, improved device reliability, and the elimination of excursions caused by non-systemic influences
Nordson MARCH
